AZ-J's Avatar
Send a message via AIM to AZ-J
BST Wheels front and rear set mismatched
I finally took the BST wheels I got a few months ago for my R1200S into my local shop with new tires. Then after that I brought the bike in.
The plan was to put the new tires on the new wheels, take the old wheels and tires off the bike, transfer the rotors to the new wheels, and put on new wheels with new tires. Yet, it turns out there was big problem as the rear wheel was OK, but the front was too wide and measured for a K1200S front wheel. It not is, but the box label says 17 X 3.5 so it is wrong.
I confirmed with the vendor it is wrong, he even discovered he has another mismatch set there. He is sending me a R front wheel now, and I have to send back my K wheel.
I only hope it comes in time to fit before I leave 7/13 for the MOA National.
’68 R50/2(1968 was Dad's then mine to 1990) SOLD
’07 BMW F800S (3/2007-9/2008) LEMON'D
'07 BMW R1200S black CF/white tank panels (acquired 10/24/2008)
My bike here:
http://tiny.cc/MyBike
Old 07-01-2009, 06:25 PM
Initials & assault rifle
cageyar's Avatar
Are you dealing with Martin Wong at MotoWheels in Sacramento, CA?
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER
1982 CBX | OLD SCHOOL
1969 H1 | QUESTIONABLE SANITY
Old 07-01-2009, 06:49 PM
Private Citizen
AZ-Twin's Avatar
It sounds like the vendor is being cool about it, stuff happens. Hope it all goes well and you get your new wheel in time.
Rob Swartzwelder llllllllllllllll 97 M900, 07 R1200s(sold), 07 G650X Challenge, 99 BMW R1100S
(Brad Z on CF Dampeners)"it's the perfect blend of sophistication and bling."
(Roger A on moderation) "
Note to thin-skins and panty-bunchers - please note smiley."
Old 07-01-2009, 06:59 PM
AZ-J's Avatar
Dealing with the BST dealer in South Africa. He has a real bone to pick with BST over this, as do I.
My bike here:
Old 07-01-2009, 07:06 PM
I don't want a pickle
bill pierce's Avatar
Bummer
My tolerance for mistakes goes down as the cost of the part goes up.
Old 07-01-2009, 07:59 PM
No try, do or not do
shreddr's Avatar
I love my BST wheels, and have had no trouble with them, ALTHOUGH, when i got my last set of tires mounted up, i was walking out of the shop and realized the rear tire was on backwards. so i took it back in and the guy says "I followed the arrows" sure enough there is a rotation direction on my wheel that is opposite what it should be. i know the back wheels on the K and R are the same, i guess they decided they could market the same wheels to the few R12 buyers out there. oh well
2017 R1200GSW Rallye Shreddr Signature Model
Old 07-02-2009, 03:18 AM
turboflyer's Avatar
Just goes to show you, take nothing at face value and check everything your self. If it does not pass the common sense test most likely something is wrong. I would love a set of those. Blue CF front and white CF rear. Or maybe just a color match lip to tie in the 05 BCP theme.
Old 07-02-2009, 05:59 AM
AZ-J's Avatar
Front wheel box says the wheel is 17 X 3.5. Pretty wheel inside box and plastic wrap is 4.0 wide. It is a BST packaging issue.
My bike here:
Old 07-02-2009, 07:09 AM
Top of the Valley
MaineRoads's Avatar
Originally Posted by shreddr View Post
I love my BST wheels, sure enough there is a rotation direction on my wheel that is opposite what it should be. l
Shred, why would there be a directional arrow on the wheel if it's ok for it to rotate either way? Just curious.
Post quality rating of .01792 or less.
2010 K1300S
Old 07-02-2009, 07:34 AM
shreddr's Avatar
good question, I suppose I ought to reach out to BST for an answer, because the spindles are radial though I doubt there is much difference in the forces it can withstand from either direction.
Old 07-02-2009, 07:37 AM
Are you sure you're measuring properly (NOT outside width). BST doesn't make a 4" front for a BMW.
Mal Glanz
Ft. Lauderdale, FL
'12 ZX-14R
'09 CBR1000RR (w/pegs & bars, now my touring bike)
'10 S1000RR & '07 R1200S (gone, but loved 'em)
Old 07-02-2009, 11:24 AM
cageyar's Avatar
My BST rear wheel has no directional arrows on it. It only has 2 BST logos on each side and a serial number plate on the rim face.
The part number is 21002-9005-16000
The description is BMW K1200 ORW 17" X 6.0"
Old 07-02-2009, 12:54 PM
cageyar's Avatar
Are you sure you measured the wheel correctly?
Rim width is measured from the [B]inside[B] edge to inside edge of the bead walls where they meets the rim not the outside width across the width of the wheel.
If you measured there your measurement will be too large.
Old 07-02-2009, 12:59 PM
