Do not take too seriously
throttlemeister's Avatar
Weird problem
Just got back from my Nordkapp trip (report and pictures to follow later, stay tuned!), and during that trip all of a sudden it started to run weird at idle.
- It is slow going down from ~2krpm to idle.
- Once at idle, it is all over the place between 1200rpm and 500rpm, going lower until it stalls
- It shakes and sounds like it is sometimes firing on 1 cylinder, which would explain it going up and down in rpms
- When cold, it idles normally.
- Off idle, it runs great as ever.
I am suspecting a dodgy lower spark cap, but that does not necessarely explain all symptoms. I haven't had time to look at it while I am back, nor to replace the spark cap. But it would help if the collective could give me a few more hints to check, or to confirm the cap is indeed the most likely suspect.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits
BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits
http://www.sport-touring.eu | http://eurotravel.photos
Old 07-06-2009, 12:16 PM
Snob Pirate
geothepencil's Avatar
Somebody snuck an R1200S motor in the frame when you weren't looking.
geo
"She sips nitro... with Phase 4 heads! 600 horsepower through the wheels! She's meanness set to music and the ***** is born to run!" Barry, MFP mechanic
BMW/Yamaha/Suzuki
I've been ionized, but I'm OK now.
Old 07-06-2009, 12:41 PM
Banned
Air leak... possibly related to the TB vacuum port. Add a TB-to-TB crossover between those ports.
Old 07-06-2009, 01:03 PM
wood-d's Avatar
I'm with you on the spark plug. I have a simple suggestion. With the bike idling, gently push on the throttle cable on each cylinder, independently. I do this where the cable is exposed where you make the adjustment to balance the TB's. If one cylinder responds 'normal' and the other stumbles, you've narrowed it down to the stumbling cylinder. I used this technique 2 weeks ago to zero in on a bad coil.
If you can't get it to idle, will it idle with the fast idle set or with a throttle lock?
If it's stumbling that badly, I suspect a primary coil, not the secondary. When I diagnosed my bad coil 2 weeks ago, the primary coil was totally dead - no spark, period.
You can always try this:
Troubleshooting Dual Spark ignition
2004 R1100S (2zars)
1957 Matchless G11
Old 07-06-2009, 01:34 PM
Reason I figured the cap: when doing a checkup before the trip, I noticed the lower cap would not 'click' on the plug like it did on the other side. I squeezed the clamp a bit with pliers (sp), but that did not make any change.
Also, while idle is bad, normal operation and fast idle are ok. The bike hauls ass. If one of the primary coils was bad, it would not run properly at all.
Old 07-06-2009, 02:12 PM
RBMann's Avatar
I had a similar problem after a tank of bad gas. I drove 4000 miles to get home, with the fast idle on so it would not die. Pulled the TBs and cleaned them with carb cleaner. It was fine after that.
Good luck-
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S.
* 2000 S, color-Salmon 108K+ -sold
* '17 Africa Twin-totaled* '09 F650GS twin-sold
* '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ.
Old 07-06-2009, 10:17 PM
...elica rossa...
RoLoo's Avatar
geo
...as long as it isn't my motor...
Have a nice day !
Ron.
R1200S + R1200RT
Old 07-07-2009, 04:05 AM
peter f's Avatar
Top to bottom (but I don't know what's in a R11 - mind)
1. Idle actuator (was my ugly idle case - Munich accepted for 2nd time my claim/guesswork)
2. Primary coil (happens after cleaning/rain/water/typhoon)
3. TPS sensor (just happens).
4. unbalanced throttle cables (least possible)
R12S, black, ex Ohlins (now WP), full HPE, RB3
Old 07-07-2009, 06:48 AM
Had a very similar problem on a long trip last year. Turned out to be a leak in the cap I put on the throttle body nipple when I "lost" my evap. canister.
99 Black r11s
02 klr 650
03 zrx 1200
08 thruxton 900
82 ascot 500
Old 07-07-2009, 05:04 PM
