Re-sync, re-sync, re-sync
Here's my problem...
I sync the throttle bodies and my 1999 R1100S runs sweet. Just fine.
However, after only a hundred miles or sometimes even less, I can feel that it is off. I have pulled the brass screws out and cleaned them, and inside. I even put a tiny bit of blue Lock-tite on the screws to be sure that they are not moving.
Any ideas guys?
Old 09-21-2009, 08:11 AM
Banned
Assuming you have no funny air leaks (such as the vacuum port below the TB), do your tuning under load by riding around with dual vacuum gauges. Or far less adequately, with a battery TwinMax which tells you a whole less but gives the mistaken impression it is more accurate because it is shiny and expensive. The cheap meter on a TwinMax probably isn't durable enough for mounting on a bike - so that's another reason to ride with vacuum gauges.
If you keep the dual vacuum gauges on for a while, you'll see perfectly clearly if your synch'ing is drifting.
A picture of my jig for riding around with gauges on an R1100S and some discussion of under-load tuning with vacuum gauges is at my recently revised and far more accessible website, see URL below.
Old 09-21-2009, 08:48 AM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
After making the mistake of wasting some time on your "elaborate" website! (laughable is the term that comes to mind first, actually...) I now perfectly understand why so many people here think bad about you...
You are an idiot IMHO! Bona fide at that... doesn't the constant talking out of your a$$ hurt over the long term?
For the longest time I was trying to stay neutral (not always easy) but, reading some of the garbage you write, I can now fully understand why people get mad at you...
I have a wonderful suggestion for you... take up gardening and start frequenting the gardening boards... there is so much you could do in terms of improving the fertilizer and application strategies, you'd be busy for the rest of your life...
As for Bob's problem... the only thing useful you had to offer was the fact that you pointed out the possibility of an air leak...
I am still laughing about "your audio club"... yeah, you strike me as such!
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 09-21-2009, 09:08 AM
Banned
Could you stick your neck out and name a couple of the things you think are wrong and say why you think they are wrong?
Old 09-21-2009, 09:13 AM
roger albert's Avatar
Airleak is a good possibility.
Riding around with a twinmax is a very good idea.
I'm on my 2nd one over a nearly 15 year period (and counting) and use it nearly every day, so I've found it to be both accurate and durable. Some of the armchair guys don't really have enough understanding of science, or mechanics, or more importantly, actual experience, to be a valid source.
I'd also look carefully at cable routing and binding. In many cases, a cable that settles at a slightly different place every time (the bars are turned), will give a slightly different routing or end-seating every time, and thus slightly different sync every time. This is by far the most common cause of wandering sync on boxers, guzzis, and old ducs etc.
hth
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 09-21-2009, 09:48 AM
Could a bad bowden box contribute to this problem? I often hear of folks saying these things start giving trouble on an older bike, although mine seems fine at 50K/10-yrs.
- Mark
Old 09-21-2009, 10:03 AM
good thought. One more place for cables to be a bit out of sync.
Either way, airleaks or, very generally, cable issues (to include bowden box) are the likely area, not the brass screws.
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 09-21-2009, 10:40 AM
Banned
Originally Posted by roger albert View Post
snip
snip
Gosh, I sure would have thought that mentioning the Motorola MPX2100DP in my vacuum gauge write-up would have established my electronic bona fides. Guess I was wrong. I hope others read my write-up and judge for themselves.
BTW, in one of my write-up I did the calibration of the TwinMax on max sensitivity. Ever wondered what you are reading on that tiny meter?
Old 09-21-2009, 11:18 AM
Nope.
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 09-21-2009, 11:42 AM
Bob, also go to a bike shop and for $10 bucks buy a cable luber.Its a little gizmo that you lock on the end of the cable and you insert the straw from an aerosol can into it and it pushes lube through the whole assembly.
I see you've let Ben back in
Old 09-21-2009, 11:51 AM
Banned
Nope.
C'mon Roger, how about 52 years designing and building electronic gear and 48 years on bikes (but only the last 43 on BMW boxers)?
BTW, Bob K, if you have a 1952 BSA, take levert's advice. If you have a BWM certainly do not.
Bob K, are you finding this thread helpful?
Old 09-21-2009, 12:01 PM
It's obviously possible to do something casually a very long time, poorly and/or to remain easily confused/confusing
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 09-21-2009, 12:13 PM
If it's not an air leak, another thing to check is to make sure you are snugging up the lock nut.
Old 09-21-2009, 12:26 PM
Living on borrowed time!
JonyRR's Avatar
As shovelstrokeded said: 'I have read this thread with some amusement'.
From the latest Psychology Today:
'******'s syndrome' is a very rare malidy manifested by a repeated issuing forth of seemingly-technology-literate psychobabble from an ersatz expert bent on trying to impress the technically challenged.
Characteristics include getting slammed for trying to shut down technical boards by threatening lawsuits, repeated user identity changes while spouting the same inaccurate nonsense and championing idiotic technnical websites wherein every detail is simply wrong.
The recommended course of treatement is self-induced lobotomy by 45ACP or alternately drinking a quart of drain cleaner.
Better a has-been than a wanna-be
'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'.
Old 09-21-2009, 12:29 PM
Use a propane or acetylene tracer to track down your air leak. If thats not it remember Jerry's suggestion to snug cable locks well. If thats not it you may want to make sure the butterflies left and right are equal........but don't get into this unless you know what you are doing. The bypass screws can mask unequal setting for the two butterflies. This has all been covered on this forum several times. Make sure your valves are perfectly set BEFORE you re set one of your butterflies to meet the other one.
Your engine should idle at equal speed left to right when the bike is run on one cylinder at a time. Remember to carefully ground the inactive plug when running the bike on one cylinder. Take care if you don't understand what is in play here.
Remember.........if the butterflies are exactly right......you can close both of the air bypass screws tight and still get perfect idle and perfect off idle balance response. Set them both to 1 full turn out however once you find the problem.
Old 09-21-2009, 05:43 PM
wood-d's Avatar
Ummm, I believe these cables are teflon lined and are not supposed to be lubed. If so and you lube them, they will likely bind
2004 R1100S (2zars)
1957 Matchless G11
Old 09-21-2009, 06:11 PM
Banned
Originally Posted by Dr. Curve View Post
snip
snip.
Thanks wood-d. But it can help a 1952 BSA!
All good thoughts from Dr. Curve - except the part about running on one cylinder. Not only are you not under load, you are not even on the "map" of the ECU. Perhaps the one-cylinder method had some value long ago, but it makes the engine run in an undefined state if there's EFI or even a CV carb. Balance with dual vacuum gauges, maybe a Unisyn, or, yuck, a TwinMax and that tells you about balance.
Dr. Curve is clear in saying not to use that method unless you also understand you can smite the high-tension network dead (or mysteriously leaky afterwards) if something slips.
Old 09-21-2009, 06:36 PM
wood-d's Avatar
And a '56 Matchless G11
2004 R1100S (2zars)
1957 Matchless G11
Old 09-21-2009, 06:43 PM
Sorry Boybiker, you are incorrect. If the problem is indeed as stated in the first post........a primary balance between both cylinders is the basic point to start from and each cylinder must start from point zero equally. Forget the other ECU or map talk until you get the most important things figured out. Have you synchronized your butterflys lately? If not, do that before you hook up any thing under load. Even with your twin max telling you are synced........you still may not be getting a even charge into each cylinder off idle because the air by pass masks quite well. BMW oilheads respond to this tuning just like their brothers of 30 years ago did......
Find the source before you worry about riding around with hook ups on.
Old 09-21-2009, 09:08 PM
Banned
Actually, I don't think "running on one cylinder tuning" worked any better 30 years ago. I may have almost convinced Snowbum of that; he uses the "screwdriver shorting" method which I think is better than your "pull the wires" method because you can both listen to each side and switch sides faster while with your method, you sure had better stop the engine before playing with the wires. (OK, you should wear your rubber boots when doing the screwdriver method - that's a downside.) Don't ask me how you compare the sound of one cylinder with the old, fading memory of the other cylinder two minutes ago.
The vacuum port is downstream from both the BBS and the butterfly. There is no way to avoid reading a mix of both with your tuning and or with funny "3000 rpm in my driveway" tuning. Screwing in the BBS, as you suggest, just means starting from zero again.
I am also puzzled when you say, "well, then just open the BBS one turn" as if that's the end of idle tuning. Far from it unless you like bad idling.
Tuning under load gets around it because only the butterflies matter much once you are under load.
But you neglected to mention the real problem with one cylinder running: being off the alpha-n ECU maps (both fuel and spark) and that is an issue for the 3000-rpm-in-driveway method too. There's no sense of tuning when the ECU is screaming back at you, "What the devil are you asking me to do?" Worse yet if you have an FRK in there which really confuses the ECU even more.
The subject of zero=zero has come up from time to time. I guess I think if you are having issues and know how to synch, then your only problem is at idle where, as you say, the BBS can interact with the butterflies to confuse things if the idle stops are wrong. With tuning under load, the butterflies always end up OK, whatever the idle stop screw is set for... but that doesn't help idle and off-idle.
If I may speculate, since I am negative about anybody doing a zero=zero as precisely as really needed, I'd say mail your TBs to Bosch during the winter for a proper indexing and a dab of paint on the screw. I suspect there are a lot of mis-adjusted idle stops out there by now.
Old 09-22-2009, 12:51 AM
