moze229's Avatar
Molykote paste on front axle...
OK, I'm getting ready to reinstall the front wheel on the R11S and the service manual tells me to apply a thin coat of Molykote paste to the axle. Can I get this stuff locally or is there something else I can use? What does everyone else use? I'd almost try to get away with what was already on there, but I'm a moron and got crap all over it so now I have to wipe clean and redo. Thanks!
Matt
Old 04-12-2010, 03:13 PM
Underwater basketweaver
SergioK's Avatar
Send a message via AIM to SergioK Send a message via Yahoo to SergioK
Hmm... so thats what that stuff was. I never actually applied new stuff to the front axle of either of my R1100S's... I suppose if I followed the book I would have. Then again, the stuff that was on there for all those years just stayed there. I'm sure your local Napa auto parts would carry any equivalent. Any anti-seize compound should work.
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 04-12-2010, 03:29 PM
Initials & assault rifle
cageyar's Avatar
You can get a tube of Honda Moly 60 paste at any Honda motorcycle dealership.
I mix it 50/50 with a high quality high temp wheel bearing grease to maintain the moisture since the straight paste can get a little dry over time. Same for my FD splines. It's good stuff and not very expensive at about $8.
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER
1982 CBX | OLD SCHOOL
1969 H1 | QUESTIONABLE SANITY
Old 04-12-2010, 03:45 PM
Jamikest's Avatar
Molykote paste has always translated to me as 'anti-seize' paste.
MOLYKOTE® P-37 ANTISEIZE PASTE
But, Molykote is a registered trademark of a line of lubes/greases/anti-seizes.. so thats rather vague :P
Old 04-12-2010, 03:57 PM
moze229's Avatar
Thanks for the info guys! So, I'll be off to the shop tomorrow if I can find the time. I need to get that wheel back on there.
Matt
Old 04-12-2010, 06:52 PM
RBMann's Avatar
Any grease will work pretty well. It is just there to help it slide and cut down on the rust.
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S.
* 2000 S, color-Salmon 108K+ -sold
* '17 Africa Twin-totaled* '09 F650GS twin-sold
* '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ.
Old 04-13-2010, 10:44 AM
moze229's Avatar
I was just going to throw some regular grease on there, but wasn't sure. It seems like it may pick up more grime than the paste, I don't know. I'm not going to be overly worried about it. I'll probably just use regular grease and see what happens.
Matt
Old 04-13-2010, 01:29 PM
cageyar's Avatar
Greases like oils and lubes, are available in a variety of grades.
While Mr. RBMann's advice is realistic, especially given his high mileage R1100S, you should try and make sure your choice is rated NLGI2, the grade for "normal" grease per the National Lubricating Grease Institute....yes, that's what it's called.
I'd choose a synthetic based NLGI2, like a Mobil 1 or some other decent brand.
I'd also say invest in the Moly 60 paste which you'll need for your final drive splines anyway and mix some in with the grease.
Then you can sleep the sound slumber of the truly obsessive lubricant as your axle will be well greased and corrosion free.
Old 04-13-2010, 05:06 PM
moze229's Avatar
That would be best, and sounds exactly like me. Unfortunately, I've just used 'regular' grease for now. Going back and reading, I neglected to bounce the front before I tightened the pinch bolts so I may get the correct lube and reinstall anyway.
BTW - the spacer on the left (looking from the front of the bike) is much smaller than the one on the right. I know I'm not missing a spacer, but it just doesn't look right. Since the axle is slightly larger in diameter on the end with the smaller spacer, is my theory correct when thinking that when one tightens the axle bolt, that it pulls the collar of the larger part of the axle against the smaller spacer, keeping the wheel in position? Does that make any sense?
Matt
Old 04-13-2010, 06:33 PM
squall_line's Avatar
Yes, the spacers are different sizes. This is to account for the ABS sensor, and to make people paranoid about their wheel being slightly off-center.
I think it also has something to do with ensuring that the front and rear wheels are slightly off-set, as well as some other obscure engineering reasons.
But, yes, once you tighten the bolt on the end of the axle, everything should snug up into place, as the axle can only travel so deep into the fork, and the spacers keep everything else at a set width to keep the forks aligned vertically and the ABS ring at the right distance from the ABS sensor.
J.J.
Mandarin / Black '99 R11S-A - black YoYo clamps, black wheels, black front forks.
Former bikes: '93 R100R, '93 K1100LT, '02 R1150RT, '03 K1200GT, '97 F650ST
Old 04-14-2010, 08:44 AM
moze229's Avatar
Thanks. I wan't really paranoid about off-center, but rather the wheel wandering around on the axle. Once it's installed, it's really hard to see that the axle is holding the wheel aligned on the left side (looking from the front). It's just strange looking because there is a regular spacer on the right. The one on the left isn't really a spacer if you ask me, at least that's not what I would call it. I'm not a BMW engineer though.
Matt
Old 04-14-2010, 11:08 AM
I wouldn't necessarily call that thin stamped piece of metal a "spacer", either, more like a "gravel guard for wheel bearings"
But still, very little reason to be worried about crushing it or anything. AFAIK, the end-bolt on the axle will bottom out before crushing anything. That's why the pinch-bolts are there - to hold the axle in place once it's all snugged up.
J.J.
Old 04-14-2010, 12:10 PM
