Will a 5.5" rear wheel off an '02 Boxer Prep w/ out ABS fit an '03 R1100s w/ ABS?
No.
Yes.
Gone Bush
I'll risk with an answer of more than one syllable and let the sparks fly where they may.
I think that, other than those from the GS, final drives on all R series bikes from 1999 to 2005 were interchangeable. The GS had a different transmission casting and swinging arm, so I'm not sure the final drive was the same. I personally changed over from some year R1150R to my '99 1100S and everything bolted up okay. The 1150R had ABS because the brake disk with ring and ABS sensor was still in place. I swapped over to the non-ABS disk from my 11S and plugged the hole where the sensor went. All was well. You'll probably need to swap the brake mounting disk over as it has the mounting for the ABS ring.
If enough is enough and more is better then too much should be just about right. Member of AAAA (Association Against Acronym Abuse) '22 H-D 'F' outfit, '46 Indian Chief outfit, a couple of early Honda Benlys, "BUBba" - R1150GS Adventure |
Dismembered
the difference between the ABS and non-ABS systems as well as the early (thick & cast) and late ABS (thin & stamped) sensor rings is the spacing of the brake rotor relative to brake caliper...the bolt pattern is the same. Some rear drives have a spacer washer to account for the difference in the thickness of the ABS rings. I bet that you won't have much problem fitting up a new fat wheel.
farkled '04 R1100S SOLD! 2012 Ducati Multistrada Pikes Peak (#072) "It is difficult to get the news from poems, yet men die miserably every day from lack of what is found there" WC Williams |
Final drives, for the purpose of Mr. Feldman's question, are all the same- the bolt pattern is consistent, and will allow wheel swaps. On the original question, yes, you can do it, but you wont have ABS. However, our R11s (production date up to 02/01, anyway) have the speedo sensor inserted into the final drive. I think only the R1150R does that (maybe)- all others seem to have their speedo sensor somewhere else. so- wheels can readily swap, but final drives not so much.
"Wow I'm an idiot, thanks bikerfish!" Harleys are like opinions, every a-hole's got one! 2001 R11S "lite", with a few mods. 2009 F800GS. has a better saddle. and other stuff. (sold) 2016 R12GSW 3Black. wow. |
The mounting stubs that the disc(rotor) mounts on are machined to allow for which ever ABS ring you have on the bike,hence why you cannot fit a non abs wheel(because they are longer) on an ABS bike.
You can do it the other way,and i have,as the ABS wheel has shorter mounting stubbs you can space the disc accordingly,as i said i ran an ABS wheel on my non abs bike for some years,but to do it the otherway would mean having to have the mounting stubbs machine down to allow for the ABS ring,early versions are a lot thinner than the latter ones. Last edited by Chris Canning; 08-05-2010 at 04:55 AM.. |
I don't want a pickle
On the bright side....................... NEW BIKE!!
The disc is simply off center in the caliper, with one pad being further out that the other..........but still clears the casting which holds the pucks.
And before fitting any other BM wheel have it checked to see if it's straight,i haven't forgotten buying a spare wheel,had it powder coated and then went to have a tyre fitted,I know the tyre guys well as friends,they were highly amused when it was put on the balancer,the comment i got got apart from the usual P taking,'We get loads in like this very few are straight'. I see there is one comment suggesting that wheels were all made the same and non abs wheels had their discs(rotors) spaced,I don't know if that is true,maybe with later bikes,you would have to confirm that, but certainley not with the early ones. |
I agree Chris. It will not work perfectly........but it will work. I have not made this conversion because I have plenty of wheels that are the right ones. If a person wanted to convert and have the disc in the center of the pucks the best thing to do is to is remove the caliper and shim or face the mounting hole area so that the fit is further from the ABS wheel. By doing this you will have converted the bike so that it can use either wheel. When the regular non-ABS wheel is needed you would reshim to size at the caliper mounting and when the ABS wheel is needed you can just bolt up and go. All of this is a lot of trouble and I agree with you, Steve, and others that a ABS will not fit perfectly on a non ABS rear............but it will fit and the bike can be converted to make it work perfectly. Too much trouble IMO, however.
