Ride Free or Die
1%er's Avatar
Originally Posted by signit98 View Post
The difference being that I am informing people of upcoming, interesting activities...
You going surfing is interesting? Very interesting to whom? Your ego. At the end of the day it's all about you, isn't it Signit 98. You snipe even the most innocent of posts. Didn't you get enough attention from your teachers in school. Do me a favor and add 1%er to you ignore list. But, you can't do that because then you wouldn't be able to get you groupies to pay attention to you. Happy New Year a$$ whole.
Old 12-28-2012, 04:32 AM
Originally Posted by JimMoore View Post
Hi Doug,
Pull in the clutch lever and tie it off. Then, looking through the starter hole, find the edge of the clutch disk. Using a small tool of some sort rotate the clutch disk back and forth as you look into the slot at the splines. The splines and disk should move in unison. If the disk can move on the splines you have trouble.
If you have a problem you can measure the play at the edge of the disk. Once it gets to a quarter inch I'd be seriously shopping for a used known-good transmission.
Jim,
Should there be any play? Looking at the hub while moving the clutch disk back and forth there is a bit of play. The total movement on the edge of the disk is less than an 1/8th of an inch. It shifts like butter, no problems downshifting or up shifting.
Here's a video of the play:
Clutch Play 12 30 12 - YouTube
Thanks,
Doug
Doug
Minneapolis, MN
'01 R1100S ABS, Öhlins, Ztechnik exhaust, Corbin "Ol' Yeller"
'03 Yamaha TW200 "Skippy"
Old 12-30-2012, 01:30 PM
The bad ones I've seen have had significantly more play than that. That could be normal wear and tear, or it could be a very slowly developing problem. IMO that's not gonna grenade any time soon. I'd button it back up and check it again in 10K miles.
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 12-30-2012, 03:53 PM
Thanks Jim, I appreciate the help!
Doug
Minneapolis, MN
Old 12-30-2012, 06:18 PM
'07 R1200S
hellfishtat's Avatar
As the originator of this thread I would like to say that the best input I got from it was a direct message (don't remember from whom) that said, and I'm paraphrasing "...stop reading the forums and just ride it..." I did that and never had any issues. At the first major service I had TjS look at it and he had no concerns. At least I don't think he did as he bought the bike from me a few months later.
Old 12-31-2012, 03:22 PM
I'm glad it worked out for you, but I don't think that's good advice. Spline failures are not rare. A spline failure will stop you dead in your tracks, and leave you there until you or someone else splits the bike in half and installs a new transmission and clutch. The problem is easy to discern through a simple check. IMO you'd be crazy to plan any type of long-distance adventure until you know the condition of your splines.
That being said, I completely understand your position. It's the dichotomy of BMW ownership. You either get a good one or a bad one. A good one will last hundreds of thousands of miles, and will be a life-long companion. A bad one will cost you multi-thousands of dollars every 30K miles. The owners of bad ones can't believe they paid money for that pile of crap. The owners of good ones can't understand what all the fuss is about.
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 01-01-2013, 01:25 AM
remember Jim, there appear to be 2 distinct failure modes.
#one is from lack of lube (factory or later).. those fails typically occur in the 70-90K range.
#two is from a trans/engine misalignment, and that is the fail that keeps repeating itself every 30K or so if left uncorrected.
#1 does not require a new trans, just a new input shaft.
"Wow I'm an idiot, thanks bikerfish!"
Harleys are like opinions, every a-hole's got one!
2001 R11S "lite", with a few mods.
2009 F800GS. has a better saddle. and other stuff. (sold)
2016 R12GSW 3Black. wow.
Old 01-01-2013, 06:41 AM
A lot of smart people agree with you on that. I'm not entirely sold. I'm in the "some are really misaligned, and others are slightly misaligned" camp.
My reasoning is this: Many, many people have gone over well over 100K without looking at the splines. Many others have broken the bike in two, only to report that "the splines were really dry, but there was no damage at all." That wouldn't happen if lubrication, or lack thereof, was the cuplrit.
That being said, I sure as hell lubed mine when i put it back together. Both times. I'm not sure it helps, but it can't hurt.
Hey, I seem to remember yours failed around 70K. How many miles do you have now. Have you checked for play recently? I'm mildly curious is all.
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 01-01-2013, 07:53 AM
failed at 71K. At 95K now. had starter motor out for nose cleaning at start of season, things looked good at that point.
Old 01-01-2013, 08:26 AM
Thanks. I hope it keeps working for you.
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 01-01-2013, 10:56 AM
Bought mine used with 54,000 miles. Just pulled it apart and the splines were very dry, a little rusty, and worn on both sides of the spline teeth. I suppose it would have worked for another 20,000 miles before it failed completely. No real noise or problems with it. I do have a whirrr-click sound down by my right foot pulling out in first gear. Everything from the shaft back seems fine and has no play or wear. The transmision ouput shaft bearing seems to have a little play so I'll look at that when I get inside. Maybe the "whirrr-click" noise is meant to be there...
Old 05-23-2013, 01:09 PM
Petie3rd
Mrmerlin's Avatar
that clicking noise is most likely the front U joint getting ready to fail
Old 05-24-2013, 04:53 AM
Thanks Mrmerlin; I'll take a closer look at that. My most current theory was that the clutch disk was chattering on its' way to full engagement although I didn't feel any slippage. Currently got the transmission mostly apart. Need better heat to get the bearings to release from the case half. Woodstove and heat gun are the current plan.
Old 06-14-2013, 03:41 PM
Instigator
Clutch hub spacer kit
Old 03-26-2014, 09:55 AM
RBMann's Avatar
Looks good, keep us up to date. Is this a one off or might you sell these?
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S.
* 2000 S, color-Salmon 108K+ -sold
* '17 Africa Twin-totaled* '09 F650GS twin-sold
* '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ.
Old 03-26-2014, 11:07 AM
Instigator
Old 03-26-2014, 11:27 AM
Brent
really if you can swing it you should just sell the modified clutch as new complete
once you have the tools it wouldn't take long to do them and most people
would be buying a new clutch anyway,
Old 03-26-2014, 08:30 PM
Brent
and I think someone is already doing something similar
Old 03-26-2014, 08:31 PM
RBMann's Avatar
Any issue with balance or getting the disc centered to the spacer?
Old 03-27-2014, 07:46 AM
Instigator
Measurements on the spacer are within 0.05mm of the original hub measurements. Holes on the spacer are at the same position as the ones on the hub.
Old 03-27-2014, 09:16 AM
