HYPER K
Disconnected O2 sensors
So now that I have a custom mapped Power Commander my O2 sensors are disconnected meaning my bike is always running in an open loop. What are the full ramifications of this?
I'm guessing it will throw a fault of some kind but I am more interested in what the bike doesn't do anymore without the sensors. Any real technical guys want to explain all this to the engine management challenged? JT |
Not sure about the fault code, but I would think you disconnect the O2 sensor because the PC is now controlling the fueling and any input from the O2 would / could throw the PC map off.
HYPER K
Yes, I know why they are disconnected. I was just curious as to what all the ramifications are. Like, does this affect the engine at altitude? Does it affect knock sensors? Will it affect fuel mileage? What all does the computer use the O2 input for?
It's gonna affect all of that, except maybe the altitude operation. Run it richer and the knock sensors won't usually matter. Run it richer and you mileage goes down. The O2 sensor only gives feedback on how much O2 is in the exhaust stream. Less O2 means richer, more O2 is more lean. For the altitude, I think there is a pressure sensor in the ECU to take care of that. Aside from all that, it's interesting that nobody has used the O2 sensors to tune AFR. Monitor RPM and skew the O2 sensor reading rich or lean at whatever RPM to adjust the final AFR. The ECU already does this by itself but tied to a specific voltage reading from the O2 sensor to provide 14.7:1 .
tm (R12, R11, R1) + 00 then S, S, /7 Last edited by tm1100s; 06-17-2011 at 08:55 AM.. |
Initials & assault rifle
An O2 sensor measures the amount of oxygen in the exhaust gas.
They provide two things;
The first chore has been taken over by your PC3. The second chore is.......no more. Previously, if the sensor picked up a rich mixture (unburned hydro-carbons), it would adjust the mixture to "add" more oxygen to more fully burn the mixture. I don't know how many miles you've ridden since the PC3 installation, but it likely would have thrown a code quickly if there was an issue. No code, runs good, don't worry, be happy. Oh, and your fuel mileage will likely drop a bit. Win-win. Drop dead algore..............
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER 1982 CBX | OLD SCHOOL 1969 H1 | QUESTIONABLE SANITY |
JT, did they disconnect the sensors and leave them open or did they install a dummy load on each one? There would be a small cap over the plug on the ECU side.
tm (R12, R11, R1) + 00 then S, S, /7 |
Usually guys who have never looked closely at an actual normal O2 sensor signal. Doesn't work well. Though an analog signal, the O2 sensor's output is a rough approximation of a square wave. i.e. except for a brief transition period (steep rise/fall times) the signal tends to hover near max or min (a bit like an injector signal, or pwm pulsetrain) As such, biasing it a bit one way or the other, as one would a temp sensor, has little, and not well predictable, effect on the output. i.e. it tweaks the waveform primarily in the region it spends little time, and does nothing for the rest of the time (can't raise the ceiling, nor lower the floor) Anyway, it's an idea that makes sense at a block diagram level, and one I ignorantly tried to play with on an old 80s audi too, but eventually, I realized what was happening. The idea comes up a lot though - it's just so much easier to spoof any number of other sensors, especially temp, or where they exist, discrete pressure (often in ECU, so not doable) hth roger
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
I'm surprised it wouldn't be easier considering bad O2 sensors that bias themselves rich or lean do it so well.
Can we buy bad factory O2 sensors right off the line that tested with a lean bias? Wouldn't THAT make algore happy.
tm (R12, R11, R1) + 00 then S, S, /7 Last edited by tm1100s; 06-17-2011 at 09:31 AM.. |
Top of the Valley
Roger, Thoughts on the Auto tune feature on a Power Commander V.
Post quality rating of .01792 or less. 2010 K1300S |
Great question, I was about to ask the same thing.
Hi guys,
PC III: Disconnecting the O2 sensors, the BMS-K goes to lambda 1 (AFR 14) and there is no error code (lamp) shown in the dashboard. RB III: eliminators should be used here. ![]() ![]() ![]() ![]()
Thanks Fralind, what engine improvements did you do to the 1100 to get this much hp?
What are the engine differences in the four 1200 runs? |
1100, etc. With Cruiser Crankshaft (1170 cc) Machined cylinder heads, 1200 S valves, camshafts, Staitune usw.
Full House. ![]() The R 1200 R Big Bore kit, complete Akra, PCIII, Boxer Burner, camshafts, The R 1200 S Different configurations Akras complete, Q-quad exhaust manifold with HPE PC III, Rapidebike 3, Boxer Burner Woessner pistons with longer connecting rods |
HYPER K
No cap. As a matter of fact about the only thing I wasnt really happy with the instalation was that they were just zip-tied open to the elements. I have since covered them with electrical tape and ziptied them a little closer so they dont flap around.
Mid Week SoCal BMW Seller
Fralind, what's the dyno type and software.
-George Hill '12 GSA, '00 Mandarin S, '09 HP2S, '99 Naked S, '03 Yam YZ250F, '91 Suz Dr350, '01 Yellow/Black S - Dead |
Specifications in DIN HP and torque curves (Nm) are the bottom lines with the points.
