Misfit
Is this the Laser DB killer?
Howdy,
Put my new-to-me Laser BC-1 mufflers on today, (sans chip for the moment) and I am wishing it were just a little quieter and mellower. Can you guys tell me from this photo, is the db killer installed in these? ![]() N.
Nils Menten - Tucson, Arizona, USA* 2001 R1100S "Light", gone but not forgotten. http://tinyurl.com/zv3tpc5 I Do Vapor Blasting! Visit restocycle.com for information. Ikon shocks for your BMW! https://www.ikonshocksusa.com/ |
Yes, the db killer is still in there.
tm (R12, R11, R1) + 00 then S, S, /7 |
Forgot the pic.
Misfit
Thanks 2x Tony. So the rounded collar is it. In your pic I see a small hole lower, that is apparently where a weld is drilled out to remove them?
How would you contrast the sound volume and quality with and without the DB killers? N.
Dismembered
![]() ![]() If you want a stranglulated farting sound go back to the stocker. ![]()
farkled '04 R1100S SOLD! 2012 Ducati Multistrada Pikes Peak (#072) "It is difficult to get the news from poems, yet men die miserably every day from lack of what is found there" WC Williams |
Misfit
N.
Actually, while there is a bit of a difference with the db killers in or out, I don't remember it being huge difference. The big difference came with the installation of the laser intermediate pipe. I think they call it the sport cat eliminator or sport cat collector.
tm (R12, R11, R1) + 00 then S, S, /7 Last edited by tm1100s; 09-05-2011 at 04:46 PM.. |
All this time and I never knew the DB reducers were there. I already did the Y pipe and am happy with the sound. Running a Dobeck FI module. Looking at the DB reducer design I cant say it is very optimum for performance. The insert has to cause a reverse pressure pulse. If they had made it more of a cone with wings holding it in place it would have reduced the noise some and even helped the flow. I may remove them just to eliminate the reverse pulse. These are not 2 stroke engines. Must not be to bad for performance or surely the Germans would have come up with a better design. But a free Hp or two cant hurt either. Undecided.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci 2007 Ducati 999S Team USA , 2005 BMW BCR R1100S 2001 Boxster S w/tip |
I have the BC-1 mufflers, cat eliminator, and chip on my '00. I recall there being some belief that the DB reducers fattened up the midrange a bit, possibly at the expense of top end power. Mine are in because it's just too GD loud without them. Other than the volume, though, it arguably sounds better with them out. You don't get the whiffly-backrap-strangulated-farting noise when they're pulled.
It's been a while but what I think I heard Foster say was that the db killers don't significantly affect performance. The smaller diameter part of the db killer is about 3 inches long and the length of that portion can be made longer or shorter to change the tone/pitch of the pipes.
I've got the Lasers w/cat eliminator and Db killers. When I got it from Foster, he asked me to try it as is. If not satisfied, then I could drill out the weld and experiment with chopping off, as I recall, 3/4 of an inch of the Db killer at a time, using stainless steel screws to hold them in. That would make it possible to moderate sound/Db, apparently. I never went through the trouble. Shine a flashlight into the exhaust in a dark garage to see them.
OTOH, if you think it's too loud now, you won't want to remove them!
Phil Y, Kapolei, HI 04 BCR (not quite stock), 06 Buell Blast (grandson's first bike), 77 R100S w/sidecar "There are old riders, and there are bold riders, but there are NO old, bold riders!" -My first MSF instructor, too many years ago |
Misfit
Imma ride it for a while and see if I acclimate. N.
Earplugs work wonders for quieting down exhausts!!
Misfit
BRILLIANT! I'll just ride my normal route with one of those giant Lab Safety 1000-packs and drop a set or two in each mailbox. Thank you Phil! ![]() N.
Dismembered
It's when you don't wear earplugs, that the Laser becomes quieter with time.
Misfit
LOL, I am already 'there'. Much hearing loss already, like many of you.
N.
