Valve train noise?
Hi everyone I am new to the site and new to BMW ownership. I have gotten a lot of info already from this site (thanks) . I just got a 1996 r1100rs about two months ago. I love it. It has 52,000 miles w / abs, black. Runs great. I just took a 100 mile this morning and became aware of some valve ticking at idle. I am not sure if I didn't here it before or it is new. I only have 500 miles on it so I am still getting used to it. Is it normal to hear valve noise or should I do a valve adjustment . The bike has been very well maintained .
Old 05-13-2012, 12:12 PM
Nitro's Avatar
Start here:
Those rocket scientists at BMW decided that it was a great idea to put TWO spring loaded tensioners on the SAME chain! After a few years they figured out to make one non-sprung, problem solved.
This is not even basic engineering, rather common sense 101 even my 7-month old dude would figure out!
Memento Audere Semper
Old 05-13-2012, 12:51 PM
tjs tjs is offline
pull the clutch lever in while at idle and see if it stops. Also worn throttle body shafts can make noise ate idle. 2cnts from tjs
Old 05-13-2012, 12:53 PM
Nitro this ticking is present after a long ride not at start up.
As far as pulling in the clutch if the ticking goes away what does that tell me?
I will listen to the throttle bodies and see if I can isolate the noise . Thanks for your help
Old 05-13-2012, 07:30 PM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
Might be valves... I would not worry too much about it, unless it is really dominant and ever present.
Check valve clearance and see what that tells you... tensioners do have a habit of doing that as well, but it's more of a rattling sound. You hear that sound for a few seconds, every morning when you start the bike...
Other than that, ride her like they donkey she is...
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 05-13-2012, 08:07 PM
Underwater basketweaver
SergioK's Avatar
Send a message via AIM to SergioK Send a message via Yahoo to SergioK
What kind of oil is in the engine? Weight? Synth/Dino? When was the last time it was changed? I've experienced varied levels of valve noise and found heavier weight oil 'cured' the issue.
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 05-15-2012, 07:14 AM
yes, some amount of valve noise is normal. however, if you do not know when they were last adjusted, or that adjustment was done over 5K miles ago- do a valve adjust. it's easy to do, and assures you that things are right in that realm.
TB shafts usually don't go out until closer to 100K miles- but also easy enough to check. place your finger on side of TB, providing external support to the shaft. if the ticking goes away- that's your culprit. supposedly, the right side is more prone to failure than the left. or vice versa, i dunno.
"Wow I'm an idiot, thanks bikerfish!"
Harleys are like opinions, every a-hole's got one!
2001 R11S "lite", with a few mods.
2009 F800GS. has a better saddle. and other stuff. (sold)
2016 R12GSW 3Black. wow.
Old 05-15-2012, 10:52 AM
Sergiok the oil was changed by the previous owner 500 miles ago. I am not sure what type he used but I know he used BMW gear oil and maintained the bike with great care. Don't want to start anything but what type and weight of oil do you like?
Bikerfish , I will try your trick with the throttle body and see if that is we're the ticking is comming from. It is dead quiet at start up and when it's cold . I didn't notice the ticking untill I took it for a long ride . I will pay more atention next ride. The carbs were sync 500 miles ago don't know about the valves.
Old 05-15-2012, 05:45 PM
Ken, do you have access to a automotive stethoscope. If so, you can pinpoint the area of the tick.
Old 05-15-2012, 05:53 PM
Ken, reasonable money would say that the valves were done at the same time as the oil/TB servicing.
do not ask about brand oil- it's a swamp of an answer.
just use 20W50, SG or SH rated. best option tofind that is to get a m/c specific oil. some like dino, oters synth, still others split the diff and go with a semi-synth (my preference).
depending upon where in NY you are, maybe one of the local pelicans can catch up with you and give it a listen.
from your description, i'd guess that the valves are a tad on the loose side. that is not necessarilya bad thing.
Old 05-15-2012, 06:01 PM
SergioK's Avatar
Not to start an oil thread... then again, it's been a while since we've had one and who knows the fireworks that will fly if we go there... I've usually ran Mobil1 Synthetic 15w-50 automotive grade oil. Anyway, it meets the recommended specs in the owner's manual.
Like I said, my bike made a ticking noise from the valves once in a while and I attribute it to the synthetic oil. Kinda of irksome but I only heard it when I came to a stop... so, no stopping and problem solved!
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 05-15-2012, 06:03 PM
Nail24, yes I do have a stethoscope and I was going to go that route the next time I heard the tic . I also only heard it when I stoped. I would love to meet up with some local pelican members. I am on long island any one close?
This is my first bike and I must say I love it. Not sure what I am going to do oil wise but I appreciate your input. I changed the trany gear lube with redline shockproof based on what I read here. It made a big difference the trany shifts much smoother now. I really wanted to check for metal in the box. It was perfect, no metal shavings
The bike is a 1996 the trans. Is black not silver , does that mean it is the upgraded box?
Old 05-15-2012, 07:46 PM
Old 05-15-2012, 07:48 PM
hugzy's Avatar
I thought my R1100s made more valve noise when I put synthetic Motorex Boxer 15/50 in it !
My throttle bodys, well at least one of them also makes alot of ticking noise that at one time I thought was coming from the valves. Again only at idle.
Old 05-16-2012, 03:09 PM
Greetings Mates
Joe Technician here,(not a moto tech), I have a 2002 R1150RT that also makes a ticking noise I have not ever been able to fully locate the source but have been riding it for the past 8 years. I did a valve adjustment and that helped a bit, put in 20/50 that also helped, but occassionally I still hear this tick after a long day of motoring. Still searching but like the others stated you can keep riding, I will put my steth in the trunk and go for a ride.(once I finish the brakes that is).
Old 05-20-2012, 11:20 AM
Misfit
Noblehops's Avatar
What about the lash on the rocker arm ends? Could that account for this noise if it were tight?
N.
Nils Menten - Tucson, Arizona, USA* 2001 R1100S "Light", gone but not forgotten. http://tinyurl.com/zv3tpc5
I Do Vapor Blasting! Visit restocycle.com for information.
Ikon shocks for your BMW! https://www.ikonshocksusa.com/
Old 05-20-2012, 03:04 PM
normally, tight = quiet, and loose = noisy.
Old 05-20-2012, 05:40 PM
Well I checked with the stethoscope after a long ride. It is comming from the valves. Throttle body is quiet. I will do a valve adjustment next week and keep you posted. Thanks for all the advise
Old 05-20-2012, 06:46 PM
Misfit
Noblehops's Avatar
Ahh, ok, thanks for clarifying BF. OP might want to check that in addition to valves.
N.
Old 05-20-2012, 07:12 PM
