Trans back into place - clutch push rod and slave cylinder help
Hi Guys.
Got the transmission bearing replaced and put everything back together to the r1100s. The trans lined up with the engine great with no problems. All gears shifts great. Thanks for all the recommendations on the previous help post. Problem I am having is with the clutch push rod inside the trans. Following the manual instructions, and when trying to put the clutch slave cylinder housing back, it won't fit due either the clutch push rod not completely going into the engine or something with the slave cylinder housing. To secure it, I would need approx 3/4 inches for the clutch push rod to go in. I remove the clutch push rod out of trans and slide it back in again but it's the same. The clutch reservoir is empty and the clutch lever is loose easy to open and close. Anybody have any recommendations of what might be wrong? Thanks all!! |
**When pulling in on the clutch lever, does it pull in/move the insides of the slave cylinder?
Originally when putting the trans back to the engine, the clutch lever could not move. |
unsafe at any speed
Push harder you have to push the piston back into the slave cylinder... it extended while it was hanging loose.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
Bingo. Thanks Bill.
I see you
sooo many jokes come to mind
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
