varmint's Avatar
Stupid Door: Inanimate Object Rant
lived here almost five years. it's always been a confusing annoyance. but i've finally come to a point where i have to figure away this around this.
this looks like a double door. but only one side opens. there are no hinges or visible latches on the other. i can't believe someone built a door this way. is there some trick i am missing? have any of you all familiar with this sort of thing? there are no identifying marks on it to look up directions. do any of you have any tricks for shoving a 34' bike through a 28' opening?
i'm a few hours away from completely dismantling it with a screwdriver.
1971 R75/5
2003 R1100S
2013 Ural Patrol
2023 R18
Old 09-17-2013, 11:15 AM
Underwater basketweaver
SergioK's Avatar
Send a message via AIM to SergioK Send a message via Yahoo to SergioK
I used to live in a house that had vinyl storm 'proof' windows. One would slide, the other would not. It 'appeared' fixed. In truth, it took was a bit of 'persuasion' and the non-sliding part would actually pop-out of the frame. I can't tell from the detail/resolution of this photo though.
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 09-17-2013, 11:33 AM
kpolito99's Avatar
Sorry to learn of your troubles. If the panel on the right has no hinges it is technically not a door but a fixed pane.
For the record I recently replaced a triple pane sliding patio door with open panel french doors and installed one fixed panel with a pair of doors. The door that has no handle is secured with two sliding latches. One latch is up top and drives into the jamb while the other near the floor drives into the sill.
If you see no hinges and no slide latches you will need to make your bike skinnier. Perhaps you can line her up at an angle and rotate the bike towards the leading jug to get through the narrow opening.
You will have the rest of your life to remember. But what you have to remember depends on what you do today.
Current ride - 2007 BMW R1200S
Past bikes/sold - 1999 BMW R1100S/1994 Honda VFR 750/1989 Suzuki Katana 750/1982 Suzuki Katana GS1000SZ
Old 09-17-2013, 11:37 AM
varmint's Avatar
would be great if it worked that way. have already tried a little bit shy of breaking it persuasion. want a plan before i go any further.
1971 R75/5
2003 R1100S
2013 Ural Patrol
2023 R18
kpolito99's Avatar
I helped the framer that installed my doors and let me tell you there are some serious 3-1/2" - 4" screws that we drove through the solid pane and into the frame of the house, jamb and footer. The solid pane that we installed is not going anywhere easily anytime soon.
I sure hope that your setup is different otherwise it will be a huge pita to take that thing down. If you do end up removing the panel I would definitely hang it on a set of hinges and make it a functional door.
Old 09-17-2013, 11:52 AM
SeabeckS's Avatar
Location: Seabeck, Washington, 20 miles west of Seattle as the seagulls fly!
Sorry to say, but that second door isn't a door. It's a fixed, full-sized "sidelight". Sort of a cheaper option than a double opening French door...but not very damn useful.
I used to pretty handy with a fire axe, that's the only way to open it...
Old 09-17-2013, 12:00 PM
There's a professional in your town that can fix this. Call door company, check Home Depot, etc.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S
'01 Boxster
Old 09-17-2013, 12:43 PM
varmint's Avatar
Took some weather stripping off. There is a mass of caulk and in accessible screws visible.
Calling in a contractor may be necessary.
Old 09-17-2013, 12:47 PM
remove the heads?
2000 Cagiva Gran Canyon
2007 BMW R1200S
Old 09-17-2013, 12:54 PM
Uh....who me?
Bob Hancock's Avatar
Yeah....that's what I'd do. Point and pay. Life's too short to get yer blood pressure up over something like this. I've got a similar rant brewing over a moto-project I volunteered to do on someone else's bike but it won't change anything to feed it, so I think I'll go to dinner. That usually helps.
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 09-17-2013, 12:59 PM
Gone Bush
twodear's Avatar
I' like to know how you got your bike up on the deck...
If enough is enough and more is better then too much should be just about right.
Member of AAAA (Association Against Acronym Abuse)
'22 H-D 'F' outfit, '46 Indian Chief outfit, a couple of early Honda Benlys, "BUBba" - R1150GS Adventure
Old 09-17-2013, 02:32 PM
onekiwi's Avatar
Swivel the mirrors and handlebars!if I was closer I would have a look at the door for you.
2005 K1200s 2004 R1100s
God bless salvage titled bikes for the working class man
Old 09-17-2013, 03:02 PM
cover glass with duct tape.
agatt...plus maybe a little more.
back bike up. warm bike up. put in first gear.
aim for that vertical white board in the center.
drop clutch.
brings a whole new meaning to the term "demo bike", doesn't it?
might want to move those dead plants out of the way first.
looks like they've had enough already.
'04 R1100s. I changed a couple o' things.
Old 09-17-2013, 03:04 PM
tm1100s's Avatar
Remove the fixed panel, clean out the jamb. With just a little know-how you can hinge the currently fixed panel, install sliding locks top and bottom and re-weatherstrip the entire opening. You'll have one regular door and the other can be opened by pulling the top and bottom sliding locks open. Easy.
tm
(R12, R11, R1) + 00 then S, S, /7
Old 09-17-2013, 03:40 PM
Honda GL1000 current ride
Martin Glasser's Avatar
Its probably an Atrium Door.... They went out of business...interesting idea a bit impractical..
Old 09-17-2013, 03:57 PM
I could retro this, where you at?
Also could describe what steps I'd take..
Old 09-17-2013, 04:00 PM
GDM GDM is offline
On the Road Again
GDM's Avatar
Perhaps in the house is not optimum.
However, when I brought my Triumph into the living room, I removed the handlebars, swung them down and to one side and pushed it through the front door (32" wide).
Coincidentally, it was about that time that my wife stopped talking to me. Never did figure out what the heck happened there - women eh.
Old 09-17-2013, 04:41 PM
BARF BIKES
BMW Roundel Man cave
Build a man cave and leave the bike in it . Not real smart putting your wheels in the house to begin with. This will be a handy place to drink beer and work on your bike. The doors come in all kinds of sizes from 4' to 16'.
Old 09-17-2013, 04:56 PM
AKA nail24.Guest24
nail24fac's Avatar
Take that door out and install a door that has to bolt lever locks on the other door so you can roll the bike inside.
06 F650GS
IBA 38801
Old 09-17-2013, 05:10 PM
varmint's Avatar
turns out the neighbor used to do window and door installation. still had to remove the glass and dig out twenty screws from the frame before we could pop out the door. will have to go through the whole process again next spring.
his wife came over to see what we were doing. she rolled her eyes and left without saying anything.
1971 R75/5
2003 R1100S
2013 Ural Patrol
2023 R18
Old 09-18-2013, 12:49 AM
