Any plug-n-play non load dependent flasher units out there?
NO PLUG-N-PLAY RELAY NEEDED TO FIX FLASHER UNIT PROBLEMS. SEE AN UPDATED THREAD HERE.
Anyone found a non load dependent replacement flasher unit that will plug into the original flasher unit socket?
I haven't opened up the flasher unit to look at the pin-out. Would it look something like this?
Cory
01 R11S
Old 04-18-2014, 06:33 AM
tjs tjs is offline
yes. tjs
Old 04-18-2014, 09:38 AM
This one will handle LEDs without the fast flash.
However , it will not self cancel ... you'll have to remember to cancel the turn signal yourself.
Flasher Relay for BMW K1200LT | BMW Motorcycle Accessory Hornig
Old 04-18-2014, 09:51 AM
Enthusiast
sirius815's Avatar
Post 25 of this thread here may be of help
http://www.advrider.com/forums/showthread.php?t=218288&page=2
Old 04-18-2014, 11:46 AM
Originally Posted by sirius815 View Post
Excellent. Thanks!
Old 04-18-2014, 05:10 PM
Enthusiast
sirius815's Avatar
No problem! Thank the guys on ADV!
Old 04-18-2014, 05:29 PM
Thanks very much sirius. I followed your link to ADV and Pool's solution. Per that information I removed my flasher unit, cut a single pc board trace and NO MORE PROBLEM! If I understand things correctly, cutting the trace re-programs the flasher unit. It is originally programmed to blink fast if a light goes out. After the cut it blinks 1x/second regardless of load.
I'm going to collect all the information I found into a thread on this topic because there is a lot of information and it is on different sites and threads.
Thanks again.
Cory
01 R11S
Old 04-20-2014, 01:31 PM
Enthusiast
sirius815's Avatar
You're quite welcome! It took me a few days to even find that one. Although, I have yet to find a flasher relay for the 12S...I want to believe the flasher is integrated into the big module. Luckily the LED drivers I have for my blinkers draw just enough current avoid the fast flasher action. (Well - I had one driver that still caused the issue, two out of three didn't).
Ben K.
Old 04-20-2014, 02:01 PM
