Pedantic Old Woman
Next Project -- Fixing Handlebar Area Wire Wrap Failure
Hi guys,
Was washing the bike today (it was filthy), and noticed that the protective tubing around the wires coming from the handgrips is cracking and failing. Here are some images: ![]() ![]() ![]() Suggestions? Is there a wrap that would work to protect these wires? Or do I have to disconnect everything and slide some tubing on there? What do you guys recommend?
Dana in Philly 2000 Mandarin R1100S On the Road Again |
For a quick fix, there is two kinds of wrap available.
Split Loom and a Spiral Wrap, both work equally as well, but the split loom is a little easier to apply and I think it looks neater for this application. Check electrical supply outlets or auto parts suppliers. Cheers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat |
Hello;
This is what I have used Weatherproof Cold Shrink Tape Part #85274 Auto-Zone carries it, work great ![]()
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel ![]() 1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
I HIGHLY recommend this stuff. I just did this project on my '99 S 3 weeks ago. It's not super expensive, it was very easy to install, it looks really good, and it feels like it will last for the life of the bike.
I bought the 5/16" diameter, 10ft length. I ran it for both wire looms from the hand controls to the relay boxes, I had a little less than 3 ft left over. Russell/5/16 in. dia. x 10 ft. Wrap-It wire sleeve (629090) | Wire Sleeve | AutoZone.com
2018 R1200GS Rallye 2005 R1100S BCR 2003 R1100S BCR #73 1998 R1200C 1966 R50/2 Last edited by BMWR502; 07-19-2014 at 04:43 AM.. Reason: add photo |
Gasteropod Rider
Used the same as proposed by EZ rider, for a damage to that exact same wire you show, 3 years later it is still working perfect.
How is it applied? What does "cold shrink" mean?
16' BMW R1200RS 09' BMW HP2 Sport 00' Harley Fatboy |
I hunt deer with my BMWs
Prepare to find out nearly all of the wires are cracking and crumbling like that. At least that is what I found on my 99 R11S.
2004 R1100SA (Street/Deer Spear) 2003 Suzuki SV650 (Track/Race CCS Expert#57) 2007 R1200S (SV650 replacement) |
When you wrap it thight against itself it bond without glue, it's made in England, similar to F4 tape but not rubber.
This Amazon.com: Coroplast Fuzzy Fleece Tape As Used By Vw, Audi, Mercedes, Bmw: Office Products is what all German carmakers use for their wiring harnesses. Coroplast Ref. 8551
A suitable alternative would be this tesa® 51006 - Products - tesa SE I have this coroplast stuff and I can say there is nothing better than that. Brgds Oliver |
I cut away the old stuff and rewrapped it with cloth electrical tape from Radio Shack.
Jim Moore Jax, FL '01 R1100S '07 CBR600RR |
BMWR502, that is a nice alternative, but my only concern is that there's a slit in it which could let water in. I actually bought tesa tape from a guy on eBay...$17 a roll but I like your idea and EZ-Rider's idea better. I'm on the fence on what to use.
A tip to keep wiring looking new is to them and any rubber parts with silicon spray a few times a year, especially before they are stored for the winter. Spray it and rub it in with your bare hands (just don't breath it in). My older bikes' wires all look like new and they are all high mileage. I also just bought 303 Aerospace protectant to try all over the BMW. Hopefully bring new life to all the wiring and dulled rubber & plastic bits. Another tip is to try to park it in the shade or under a cover if it's outside.
16' BMW R1200RS 09' BMW HP2 Sport 00' Harley Fatboy Last edited by maverickma; 07-19-2014 at 04:58 AM.. |
Pedantic Old Woman
Meh. The wires look good. It's the protective tubing that's done for.
But OK, I take your point, and it is time for a new battery. Might as well pop up the tank and have a look around in the snakes nest under there.
Understandable concern... the split in the loom doesn't just "butt" together though, it doubles over on itself and holds a very tight curl. Being behind the fairing, I would think it would be fairly difficult for water to be forced into the loom.
2018 R1200GS Rallye 2005 R1100S BCR 2003 R1100S BCR #73 1998 R1200C 1966 R50/2 |
BMWR502...hmm ok. So what did you do...take the tank off to get to both wire bundles?
16' BMW R1200RS 09' BMW HP2 Sport 00' Harley Fatboy Last edited by maverickma; 07-21-2014 at 07:41 PM.. |
Registered Agitator
I've been using Wonder Wrap for years for projects like this where you don't want to take everything apart to wrap it. It fuses to itself almost instantly & only gets stronger as it sits, also totally waterproof. Comes in colors too but I've only used black
Miracle Wrap Home | Miracle Wrap |
You beat me to it. I spent about three days stripping, cleaning, and rewrapping the vast majority of the harnesses on my bike after I bought it. The more I looked, the more I found. I bought a package of black zip-ties and re-secured them all when I was done.
Hope you haven't tightened the zip-ties too much. That is a very common source/problem for the broken plastic stuff covering the wires.
There is a good reason why most manufacturers use that coroplast stuff ... Brgds Oliver |
Question for BMWR502
BMWR502, hoping you see this post or the PM I sent you. Do you remove the old wire covering before you installed the Wrap-it split wire loom? I now have some wrap-it on hand, but it looks like it will only fit if I cut off the old stuff. Thanks. Doug
