LinkBack | Thread Tools | Rate Thread |
When replacing the Eprom chip, does the gas tank need to be completely removed?
In a non-ABS R1100S, when you replace the eprom chip located in the control unit under the gas tank, does the tank need to be completely removed or can the control unit be removed with just the tank detached in the rear and propped up?
16' BMW R1200RS 09' BMW HP2 Sport 00' Harley Fatboy Last edited by maverickma; 10-20-2014 at 07:54 PM.. |
It's been a while but I don't remember having to remove the tank completely. You can prop the tank and get access to the screws to release the ECU.
tm (R12, R11, R1) + 00 then S, S, /7 |
Brent
you don't need to remove it, but don't drop it, I usually remove it.
Why would you want to leave the tank on
take it off it's a 2 minute job and you want to start delving into the ECU
Ok, haven't actually moved or removed it yet so I wasn't sure how difficult it is. I know I need some fuel line clamps which I found at HF which I will buy. I even have a new battery and air filter waiting to be installed, but riding that darn thing gets in my way since its so much fun.
16' BMW R1200RS 09' BMW HP2 Sport 00' Harley Fatboy |
As I recall it was a bit of a pain to try and reach under and I eventually removed my tank.
My recommendation would be to purchase two pairs of quick disconnects from A&S Cycles or some other shop and to install the QDs after/while removing the tank to upgrade the chip.
You will have the rest of your life to remember. But what you have to remember depends on what you do today. Current ride - 2007 BMW R1200S Past bikes/sold - 1999 BMW R1100S/1994 Honda VFR 750/1989 Suzuki Katana 750/1982 Suzuki Katana GS1000SZ |
Thanks for the info guys.
Buy a couple of clamps for the fuel pipes undo the two clips and pull the pipes off and it's done. |
Ok, and hose clamps are inexpensive. I'm surprised I haven't needed them before. Always removing tanks from the bikes.
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S. * 2000 S, color-Salmon 108K+ -sold * '17 Africa Twin-totaled* '09 F650GS twin-sold * '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ. |
Yea I have to do that as well not very QD is it
and of course that's the easy bit when you put them back together you have to work around the wooden block while connecting the QD it's one of those ideas on paper is great in reality it's BS.
If the QDs are hanging on the side then why mucking around in back by the wood block?
Chip?
maverickma - What chip are you going to put in your R1100s?
Let us know what you think after you get it in and ride the bike for a while. |
Because their underneath the tank so unless you have hands of a 5 year old they still need to be connected and you need room to do so.
