Rear main seal help
Hi guys,
New member but having searched the forum, I've not seen anything of this sort yet. Long story short, I recently replaced my rear main seal in my r1100s (preemptive strike while I was changing the clutch pack out) and about 300 or so miles after replacing it, it starts leaking again. When I opened it up again to see my idiotness, I see the seal is inverted on the shaft, as in the sealing membrane is pointing the opposite direction from instillation and opposite to how BMW says it's supposed to be. What could I have possibly done wrong to cause the seal to invert? Is there excessive pressure in the engine? Bent seal? And what can I do to prevent me from having to spend another weekend tearing it apart again after replacing it again. Thanks in advanced for any help.
unsafe at any speed
You have to use a special tool to push the lip of the seal toward the engine when installing. There are two seals. an inner one and an outer one with a space between them.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
Special Tool
I've looked everywhere for the tool but couldn't find it.
Could you point me in the direction of how to purchase it or could I buy it off of somebody? I ended up using directions found in this forum along with the haynes manual to install it without the tool. Thanks again. |
Brent
I use a cut aluminum coke can it is about the perfect diameter
you will need 2 use the bottom of one to invert it then slide it over the other one then the cut end is a perfect fit over the crank, you can slit it to make it smaller but no need really also it looks like you didnt leave a space between them. normally if I remember correctly the inner one sets fully into the block against the machined flange the outer larger one is just flush with the face of the block it looks like you pressed it in to far. I use a large pipe coupler to drive it, I forget which size but is is a stock part that I sanded one end flat on. or you can order the tools from bmw. |
unsafe at any speed
You can take a tapered plastic yogurt cup and carefully cut the bottom out at the point where it just fits the outside of the crankshaft. oil the seal and slide the seal on from where the bottom of the cup used to be so the lip of the seal is bent inward towards the engine. then slide it over the crank and press the seal into the block
unsafe at any speed
Ha.. Brent is quicker on the trigger than me.
Brent
also you can run the motor without the transmission in place to check for leaks.
just be careful to not let the throttle bodies suck up any debris |
unsafe at any speed
Great tip Brent!
Brent
yea brent is under employed and I have about 6 bikes to get ready to flog this summer.
Thanks for everybody's responses.!
For the install I ended up putting the seal around a plastic water bottle that fit snugly around the shaft, then tapped it in with the old seal. I seeded it in until it bottomed out onto the second seal, perhaps that was a mistake. How deep is it supposed to be? Is 3mm correct? I never thought of running the engine without the transmission installed but I'll give that a try. I'm still looking for that factory tool though. |
I can help with your quest, brent. Make me up a couple of those oh-so-cool sta-in-tune DB killers I saw on your bike in a post somewhere. ![]() J.S. |
unsafe at any speed
unsafe at any speed
if you follow the arrows you can see the ventilation system goes through the crankshaft, between the two seals then out the fitting to the vent hose that connects to the air box. If the seal is covering the hole in the block, you will likely blow another seal out, maybe the front one.
Because of the one failure, would it be a smart move to replace both seals now?
Just to confirm, the rear seal is seated all the way to the engine case and the front seal is flush with the outer rim. This has been very helpful information. |
unsafe at any speed
Yes, replace them both.
I can not remember if there is a a stop for the inner seal or if it is possible to push it in too far and have it rub against the bearing journal… when you get them out you should be able to see. the outer one is flush against the outer surface.
I looked at a photo and it appears there is a step in the engine case that the inner seal gets pressed against to set the depth. The outer seal should be flush with the engine case. Getting the lip of the outer seal facing inward and over the crank is the only hard part. Here are some pics you might find useful.
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S. * 2000 S, color-Salmon 108K+ -sold * '17 Africa Twin-totaled* '09 F650GS twin-sold * '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ. Last edited by RBMann; 04-06-2015 at 10:14 AM.. |
Oops, one more showing a properly installed seal.
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S. * 2000 S, color-Salmon 108K+ -sold * '17 Africa Twin-totaled* '09 F650GS twin-sold * '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ. |
I won't have time to work on it until next week but I'll take this advice and let you all know how it goes.
Thanks for everybody's help!
| Tags |
| rear main seal |
