No Start Problem - 1999 R1100S
Hello All,
I have a 1999 R1100S which won't start. The day the problem occurred I filled the tank in the morning, rode for about 20 miles with no issues. About 4 hours later, rode about 2 miles and while idling at the intersection, the bike died and I had to haul it home. I noticed in prior months that when I hit the throttle hard at about 3000 rpm, it would bog and jump pretty bad... almost like it was dead until I let off the throttle a little... but this didn't happen all the time. Here's what I've done so far:
Any help would be greatly appreciated. Thanks, Brian |
I bet you have a line blown off in the fuel tank. OR a split line in the tank which finally split so far that the bike quit. Or just a bad fuel filter. If you have spark you HES is good, I'm pretty sure.
Before you pull your tank off I'd check all my fuses and relays and make sure they're press in all the way.
Jim Moore Jax, FL '01 R1100S '07 CBR600RR |
I had the bogging, slogging issue you describe. After many months and wasted money, it turned out to be a slipping rotor on the crankshaft pulley. The rotor that spins about the hall sensor needs to be screwed and glued, with loctite black max. Once I did that, it was fine. Probably not your problem, but if I mention it in every bogging down bike thread one day I'll look like a hero!
Brent
have compression?
check the ignition timing. |
Thanks Guys,
Will check fuses, slipping rotor, tank lines, and compression/timing... will be a learning experience for me, which I'm up for... haven't done compression or timing before so may take me some time to get back. Thanks again! |
diz plaz is cwazy
Did you check the emergency cut out on the handle bar?
Life rewards action, He who is not afraid is safe! A Zest for living requires a willingness to die! -------------------------------------------------------- BWM R1100S 2004 (fat girl) BMW S1000RR 2011(skinny BMW R1200S 2007 (stingger) Honda CX500TC 1982 (turbo) |
Registered Agitator
It's called a "kill" switch in these parts of the woods, Rique.
diz plaz is cwazy
I put together the words kill and woods and I´m thinking deep inside Appalachia which is OK then.
Hello All,
Thanks again for the help... just providing an update as to where I'm at now. - pressed relays and fuses in all the way - drained tank, replaced fuel filter, lines looked good, filled with new fuel Tried starting again, but no luck... turns over still, but no cough/pop. My next steps will be to check the slipping rotor, check timing and compression... can anyone point me to good references for timing and compression. What I've seen so far for timing assumes the bike can be started. CoffeeGuy, in regard to the slipping rotor and use of loctite... do you mean the screw that goes through 2 and 3 of the below graphic? https://goo.gl/photos/4dk3CdzqZ63kiGB67 Thanks again for all your help, Brian Last edited by bcscott; 07-10-2015 at 09:42 AM.. |
Yes, the rotor is #2 in the illustration.
There is a notch in the rotor or pulley so that they seat together before screwing down or tightening the bolt. I always wondered why BMW didn't just tack weld the two together. |
Crack them open, clean the surfaces, and re-adhere them together. Somewhere in the tech manual it says to use the black max stuff. Might as well get a new belt on there too while you're in there. |
Talk Less, Say More
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
Probably a tired battery. how olden is it?
cRaIg CaRr 2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer. |
Tags |
no start , r1100s |
