No Start Problem - 1999 R1100S
Hello All,
I have a 1999 R1100S which won't start. The day the problem occurred I filled the tank in the morning, rode for about 20 miles with no issues. About 4 hours later, rode about 2 miles and while idling at the intersection, the bike died and I had to haul it home. I noticed in prior months that when I hit the throttle hard at about 3000 rpm, it would bog and jump pretty bad... almost like it was dead until I let off the throttle a little... but this didn't happen all the time.
Here's what I've done so far:
  • changed spark plugs - also checked for and found spark by grounding each plug to head while trying to start
  • checked air filter - also tried starting without air filter in
  • pulled each fuel injector and while trying to start noticed fuel mist/spray
  • battery appears to have full charge as my battery tender shows green
  • with everything back together, still no start... not even a pop... did try a small amount of starting fluid in each cylinder and got just a few pops.
I've read on a few forums that the Hall sensor might be a problem, but one thing I'm confused about is if I'm getting spark and fuel, why I wouldn't at least get a pop when trying to start.
Any help would be greatly appreciated.
Thanks,
Brian
Old 06-20-2015, 01:15 PM
I bet you have a line blown off in the fuel tank. OR a split line in the tank which finally split so far that the bike quit. Or just a bad fuel filter. If you have spark you HES is good, I'm pretty sure.
Before you pull your tank off I'd check all my fuses and relays and make sure they're press in all the way.
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 06-20-2015, 01:24 PM
CoffeeGuy's Avatar
I had the bogging, slogging issue you describe. After many months and wasted money, it turned out to be a slipping rotor on the crankshaft pulley. The rotor that spins about the hall sensor needs to be screwed and glued, with loctite black max. Once I did that, it was fine. Probably not your problem, but if I mention it in every bogging down bike thread one day I'll look like a hero!
Old 06-20-2015, 01:45 PM
Brent
have compression?
check the ignition timing.
Old 06-20-2015, 02:37 PM
Thanks Guys,
Will check fuses, slipping rotor, tank lines, and compression/timing... will be a learning experience for me, which I'm up for... haven't done compression or timing before so may take me some time to get back.
Thanks again!
Old 06-20-2015, 02:54 PM
diz plaz is cwazy
RIQUE's Avatar
Did you check the emergency cut out on the handle bar?
Life rewards action, He who is not afraid is safe!
A Zest for living requires a willingness to die!
BWM R1100S 2004 (fat girl) BMW S1000RR 2011(skinny
BMW R1200S 2007 (stingger) Honda CX500TC 1982 (turbo)
Old 06-20-2015, 06:27 PM
CoffeeGuy's Avatar
I've been there...
Old 06-20-2015, 07:13 PM
Registered Agitator
sgoodwin's Avatar
It's called a "kill" switch in these parts of the woods, Rique.
Old 06-21-2015, 11:11 AM
diz plaz is cwazy
RIQUE's Avatar
I put together the words kill and woods and I´m thinking deep inside Appalachia which is OK then.
Old 06-21-2015, 11:43 AM
Hello All,
Thanks again for the help... just providing an update as to where I'm at now.
- pressed relays and fuses in all the way
- drained tank, replaced fuel filter, lines looked good, filled with new fuel
Tried starting again, but no luck... turns over still, but no cough/pop.
My next steps will be to check the slipping rotor, check timing and compression... can anyone point me to good references for timing and compression. What I've seen so far for timing assumes the bike can be started. CoffeeGuy, in regard to the slipping rotor and use of loctite... do you mean the screw that goes through 2 and 3 of the below graphic?
https://goo.gl/photos/4dk3CdzqZ63kiGB67
Thanks again for all your help,
Brian
Old 07-10-2015, 09:11 AM
Yes, the rotor is #2 in the illustration.
There is a notch in the rotor or pulley so that they seat together before screwing down or tightening the bolt.
I always wondered why BMW didn't just tack weld the two together.
Old 07-10-2015, 10:15 AM
CoffeeGuy's Avatar
Originally Posted by bcscott View Post
Hello All,
Brian
The Loctite Black Max 380 is an adhesive, and isn't applied to the screw. It's applied to bond #2 and #3 together in the photo you posted above.
Crack them open, clean the surfaces, and re-adhere them together. Somewhere in the tech manual it says to use the black max stuff. Might as well get a new belt on there too while you're in there.
Old 07-10-2015, 04:31 PM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
Probably a tired battery. how olden is it?
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 07-10-2015, 05:01 PM
Tags
no start , r1100s
