1100S transmission / gearbox noises
Hi,
I'm having some noises I'm not sure to worry about or not... Clonking noise in neutral at low revs (>1000 rpm). Have heard this is common and normal though. Sometimes a noise when starting, almost like breaking a stick of wood against your knee, “snapping” perhaps is an adequate description Occasionally some clicking, rattling noises when accelerating hard from low revs (around 3-4000 rpm) Besides this no issues with the gears, no false neutrals, no gears jumping out or similar. Bike is a -99, has 16k miles, and no clutch spline wear. What do you make out of this...? Sent from my iPhone using Tapatalk |
Brent
check the drive line and piviot bearings front and rear.
drain the fluid in a clean white container and check for debris. fd as well |
Check your throttle bodies. This might be where your rattling noise is coming from.
dee jones |
The noise on startup is (probably) chain slap. You can get an upgraded cam chain tensioner com the dealer or elsewhere that will eliminate the noise and reduce the chances of breaking the chain guides.
notice any difference in sound or frequency with the clutch lever engaged or disengaged?
J.S. |
Throttle bodies were synced recently when it had its service done.
Regarding the bearings how do you check them, is it normal for them to wear out at 15k miles and what are the general symptoms...? The startup noise I've heard only 5 times or so during the last week, never before - again may I ask why this is happening and would there be any other symptoms...? Thanks a lot Vic Sent from my iPhone using Tapatalk |
About $100 from any dealer. I got mine from rubber chicken. There is more information online about this than you could possibly ever want to know. https://youtube.com/watch?v=SkPrIEzaAMs Last edited by CoffeeGuy; 08-10-2015 at 04:06 PM.. |
I like to keep my idle a little higher, 1200-1300 rpm. You can adjust it using the big brass screws that face backward on the throttle bodies. Try a quarter turn to the left with each screw. If you like it, turn it another quarter. If not, turn it back.
Jim Moore Jax, FL '01 R1100S '07 CBR600RR |
Good point Jim. I have mine set at 1200 as well...
