Gasteropod Rider
Foam stuff on the shift lever
How do I put the foam stuff on the shift lever ? I'm talking about the foam that goes around the miniature ball joints.
http://forums.pelicanparts.com/uploads6/DSC000251137067618.jpg I have removed the entire assembly, but short of dismantling the small ball joint (how? I removed the pin but it still doesn't want to disconnect) I don't see how these are supposed to get in place. |
Registered Agitator
It takes some force to separate them after removing the pin. Personally I haven't had them on mine for many years & just give them a shot of chain lube every once in a while. They don't appear any the worse for wear, still tight.
Gasteropod Rider
Nevermind, the ball joint just snaps out if you use a small 8mm open wrench as a ball joint fork.
