Jon
BMWWERX's Avatar
o2 sensor wires too short for new y pipe
Just installing a laser y pipe on my 99 r1100s only trouble is the bung for o2 sensor is several inches back from where it was on the cat converter. Uurrgh! Any chance there is a simple solution to my dilemma. seems odd but likely the location of sensor has changed with different years.
Do I have to cut and splice an extention to the wires?
Any wisdom would be appreciated big time!
Old 05-16-2016, 10:02 PM
lennie's Avatar
if you remove the body work and tank you can reroute the wires so that they will reach.
Lennie
www.boxer-performance.com
1998 R1100S Yellow is the best (now departed from my life)
Old 05-17-2016, 03:13 AM
Jon
BMWWERX's Avatar
Good news
There is enough length in there, that is great. Anything else I should do while in there? Can the tank be lifted up without removing fuel lines etc.
Thanks for the help on this!!!
Old 05-17-2016, 05:37 AM
It can be carefully lifted up without disconnecting if you have someone to help hold it there while you do the rest of the work. The later models definitely have quick disconnects which makes it painless, I don't know if earlier models have them though. If you do have quick disconnects I'd just take the take off entirely and check / clean everything under there while you're at it.
Old 05-17-2016, 07:12 AM
Jon
BMWWERX's Avatar
After removing the right side panel I was able to use a long screw driver to reach and slide two zip ties off the looped up o2 sensor wire harness. Rerouted it and all done. now on to the cam chain tension-er replacement and the oil sight glass too. Good times...
Old 05-18-2016, 07:21 AM
