tm1100s's Avatar
Upper ball joint tools.
tm
(R12, R11, R1) + 00 then S, S, /7
Old 06-01-2016, 10:07 AM
victorlaszlo's Avatar
Originally Posted by brentw1 View Post
technically I think this is one of the nuts that is supposed to be replaced.
bmw has some micro capsule thread locking stuff on it.
but honestly I dont think anyone does, thread locker wont hurt anything when you put it back together.
the manual says
Fork bridge to front frame
(clean thread + Loctite 2701)...................... 130 Nm
they also say to heat to 120c to remove but I havent had to.
the parts are all steel there are several things that should be heated to take apart
but they are alloy.
120 is quite a lot but how do you do that considering you need to hold the nut with an Allen key?
Old 06-01-2016, 10:55 AM
Originally Posted by Chris Canning View Post
Blimey your starting to confuse me!!
You need a 22mm socket with a hole in for the Allen key and I've only ever found you get that with a spark plug socket.
Re the toque without the Allen key in middle you could turn that nut forever it won't come off,just tighten it too taste,the only time I ever use a torque wrench on the 1100s is the back wheel.
Getting confused too; is the nut 14 or 22 mm? Which equals the inner diameter of the socket (not the outer)
Old 06-01-2016, 10:57 AM
How do you get the bmw roundel out without damaging it? Wanted to check if my sockets work before ordering new ones
Old 06-01-2016, 01:19 PM
The nut is 22mm you'll work it out when looking for 22mm socket with a hole in it.
Old 06-01-2016, 01:36 PM
Thanks Chris. And the badge, how is that one removed? Have tried some prying, but it feels brittle and I'm afraid of snapping/cracking it. Does it snap in, screw in, is there a trick?
Old 06-01-2016, 02:04 PM
Brent
you dont need to remove the badge
leave it alone, the ball joint is underneath it but you arent going to remove it from
the top clamp
Old 06-01-2016, 02:32 PM
Brent
the final torque wont move the center pin
just be careful to calculate it if you use a crows foot
I just tighten it
Old 06-01-2016, 02:34 PM
I'm referring to the badge covering the nut where the socket goes in this screen shot :
Old 06-01-2016, 02:37 PM
Brent
that photo is not a 1100s
the nut is on the bottom under the front frame
the photo appears to be a r1100rs not the same mounting
look on ebay for samples of what you should have
Old 06-01-2016, 03:22 PM
That explains things - thought it was the same clamp LOL
Had a look at mine and I seem to have a 21mm nut, perhaps it's different on the earlier machines...
Regardless, it will be tight with space in there :O
Old 06-01-2016, 04:05 PM
