Upper ball joint tools.
tm (R12, R11, R1) + 00 then S, S, /7 |
120 is quite a lot but how do you do that considering you need to hold the nut with an Allen key? Sent from my iPhone using Tapatalk |
Getting confused too; is the nut 14 or 22 mm? Which equals the inner diameter of the socket (not the outer) ![]() Sent from my iPhone using Tapatalk |
How do you get the bmw roundel out without damaging it? Wanted to check if my sockets work before ordering new ones
The nut is 22mm you'll work it out when looking for 22mm socket with a hole in it.
Thanks Chris. And the badge, how is that one removed? Have tried some prying, but it feels brittle and I'm afraid of snapping/cracking it. Does it snap in, screw in, is there a trick?
Brent
you dont need to remove the badge
leave it alone, the ball joint is underneath it but you arent going to remove it from the top clamp |
Brent
the final torque wont move the center pin
just be careful to calculate it if you use a crows foot I just tighten it |
I'm referring to the badge covering the nut where the socket goes in this screen shot :
Brent
that photo is not a 1100s
the nut is on the bottom under the front frame the photo appears to be a r1100rs not the same mounting look on ebay for samples of what you should have |
That explains things - thought it was the same clamp LOL
Had a look at mine and I seem to have a 21mm nut, perhaps it's different on the earlier machines... Regardless, it will be tight with space in there :O Sent from my iPhone using Tapatalk |
