Temp Spoofers
I'm not willing to go all in on a Power Commander and the associated dyno runs and custom tuning, so I wanted to see if there was any current feedback on the use of a temp spoofer and if it helps with fueling and throttle response. I also don't want a significant drop in milage.
I know there is a lot of info on the list, but much of it is dated. The players seem to be Booster Plug (reasonable at $150), and then AF-XIED and FRK at $379 and $293 respectively. Seems like a crazy amount for some resistors in molded plastic for the latter two? I have no idea if the AF-XIED is any different from a regular spoofer? Any current input from anyone that has added one of these and the effect that it had? I just have an Akro slip-on and the cat is still there. No header replacement. Thanks!
BeemerBob 2015 R1200GSW 2009 R1200GS - sold 2007 R1200S - sold and bought back!! |
Can you spare .1 cent for a resistor?
I just installed the AF-XIED on my R1100 (yesterday) and it had the same terrific effect it did on my R1150...
Smoother response across the rev range.... guess you need two for the dual sensored 2015 GS. |
Hi Bob,
The booster plug is an air temp spoofer and makes the ECU " think" ambient is colder than actual, causing it to enrich the mixture. The AF-XIED ( which I have and like) is an oxygen sensor spoofer and is in line with each oxygen sensor. This nice thing is you can tweek the mixture by turning a potentiometer. To nitro's point I hope there's more to it than that, at least it has enough internal logic to make 3 LED's blink! The disadvantage to both is that there is no provision to adjust the ignition timing. Last edited by lisc; 08-16-2016 at 01:59 PM.. |
'07 R1200S
after reading all the propaganda on the Booster Plug website, I decided to get one. I hope it will be here in the next 2 weeks. I have a R1200S with Remus header (with oxgyen sensors) and a Akrapovic slip on.
I do not know of a dyno guy locally that I trusted with my BMW (they mostly do HD) and I didn't to pay some chuckle head bouncing my bike of the rev limiter multiple times in hopes of getting it setup correctly Once I get it installed I'll let you know what I think.
Cheers! |
Looking forward to hearing how it goes.
Do not take too seriously
I have used a Boosterplug on my K and it works. But it is not some magic pill, be all cure all. Be realistic in your expectations. If the bike is stock, it works pretty good. Not perfect, but likely good enough. If you did changes to exhaust, filters, cat, etc, it is going to improve things but likely not sufficient enough to fix the problem you feel needs fixing.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits http://www.sport-touring.eu | http://eurotravel.photos |
![]() That said, still not entirely happy and still contemplating the Rexxer route as well.
The air temp spoofers all work on the theory that by making the intake air look cooler the ECU will add fuel. While true at first, both the Motronic and BMSK ECUs have powerful software that negates the "error" that they detect from the "wrong temperature" being supplied. It is easy to measure and show that this happens: 2004 R1150RT Wideband O2 Sensor Project (and AF-XIED for BMW) | Page 40 | Adventure Rider. The AF-XIED works by knowing that the ECUs use the O2 sensor as the fueling standard for all final corrections and compensations. Since whatever the O2 sensor indicates IS the ECU's reference, the ECU will never try to correct it. In fact the ECU adjusts fueling and creates fueling trims that add an amount of fuel, to all fueling situations, equal to the shift dialed in on the XIED. So for example, if you set the AF-XIED to shift fueling by 6%, the ECU will after a short time, add 6% fuel to all Open and Closed Loop fueling. One way to keep the air temp shift from being negated is to disconnect your O2 sensor(s). That however disables the ECU's most powerful feature, long term adaptation. |
It also puts the ECU in emergency mode which results in an AFR of around 12:1, which negates the reason for installing any device in the first place.
You're right about the ECU entering limp mode but my Wideband O2 measurements show that the BMW/Bosch limp mode actually shifts the fueling several percent leaner then several percent richer than stock from about 14:1 to 15.4:1. The reason is to bracket the operating range of the cat.
![]() Runs pretty nice though, but a fuel consumption of 23mpg (US) or worse is not exactly usable with a total of just 4.7 gallons of fuel.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits http://www.sport-touring.eu | http://eurotravel.photos Last edited by throttlemeister; 08-25-2016 at 03:42 AM.. |
From 0 to 50% throttle it happens over the first tank or two of fuel. Depending on how you ride, several more tanks of fuel for all the long term trims to fully develop and for the gains to propagate to the 50-100% range.
Now I know a lot of what went on with mine but not everything and I realise it spent some time on a dyno well in actual fact most of the day!! But even allowing for the camera sound and many other variables its a billion lights years away from how yours sounds. |
What would be the advantages of a Rexxer reflash versus AF-XIED? Both are in the $300 range here in the USA.
Rexxer is a custom fuel map written by Rexxer depending on what spec you have your bike at but rather than me write war and piece search Rexxer on here there is plenty on here and for those who don't know no you can't have an 1100 remapped with Rexxer.
'07 R1200S
After installing the header and slipon, the only thing I have noticed is a more pronounced lag in throttle response near redline when shifting up to the next gear, there is more lag before the fueling begins. I am hoping that this will help that
I also get a lot of popping on decel (which I don't mind)
Cheers! Last edited by hellfishtat; 08-25-2016 at 12:06 PM.. |
