Detro996
Possible Bad Cam Chain Tensioner
Hey guys, as usual I'm looking for advice. I had a ticking develop a while back and it was weird because it was intermittent. My bike has had the upgraded cam chain tensioner on both sides and it is now at about 50K miles. Anyway typically when I start hearing ticking I know it is time to adjust the valves which I did. By the way my ride intervals can be up to a month as my rides these days consist solely of going to the mtns for a couple of days. Other than that she is a garage queen.
But after the first adjustment on the next ride I kept hearing the ticking, there again it was intermittent. So when I got back home I checked the valves and nothing was extremely loose but a couple not exactly as tight as I wanted them. Then after a month or so I made a trip and this time the ticking was even worse. So this past weekend we went and the night before I checked the valves and everyone was spot on, where I've put them many times. So this time on the ride the ticking became so bad that when I pulled up from a stretch my friends noticed and pretty much anyone within earshot could hear it. But then you sit there and take a break and when you crank it up to go it is not doing it. While you are riding it doesn't increase in sound nor do you even hear it while riding. Well when I pulled in yesterday morning it was ticking really bad especially in the garage, so I left the bike running and got down by the right cylinder and sure enough that is where the ticking was coming from, the right cylinder. I cannot say definitively though that it was the cam chain tensioner. But that is what it sounds like to me. So my question is, can these things go bad and not pump up intermittently or is it an all or nothing proposition. Does it make sense that it could not be pumping up at times but be doing it at other times? Any help or advice as always would be greatly appreciated. I did some searches but couldn't find much info as all of it was mainly on the upgrade. |
unsafe at any speed
put your finger on the throttle pulley where the throttle cable attaches... if it gets quiet when you push against it, it is probably a worn throttle body.
there are threads here showing how to rebuild them.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
Detro996
but thanks, I had recently run into that information searching for something else and that was the first thing I tried. |
unsafe at any speed
Have you adjusted the play of the rocker arms between the mounting blocks when doing valve clearance adjustment?
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 Last edited by wswartzwel; 11-07-2016 at 08:05 AM.. |
Detro996
Well no, I sure haven't. To be honest didn't know that was something that needed to be done. I'll look it up in the Service Manual, but you are sounding pretty confident these cam chain tensioners must not wear out.
Detro996
Detro996
Disregard Bill, finding tons of info on the subject. I'll figure it out and check that before replacing the tensioner. Have you ever heard of one out that made a lot of noise.
Adjusting
Should be the same for hte R1200s |
unsafe at any speed
To answer your question Jeff, I haven't seen any of the newer adjusters give problems. Thats why would look for some of the more common ticking sources. Yes they make a light knocking sound when the clearance is loose.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 Last edited by wswartzwel; 11-07-2016 at 08:06 AM.. |
Underwater basketweaver
My '01 would do that, randomly... out of the blue. Then, it'd just magically go silent on me. Irked me to no avail as I never found the culprit.
'05 R12GS '08 HP2 Sport '16 GT4 |
Detro996
Either that or a broke spring or something very hard to find. |
Detro996
Thanks Bill, on the right side exhaust rocker I have more .63mm slop, that is the largest feeler gauge I have and it goes in and out effortlessly max slop is .30mm. The rest are all on the low side of spec, on both sides I do have question though. I've found conflicting information. One article says to loosen all valves and then adjust rocker arm slop. Then I found another that says to do it after you adjust the valves. What gives ?
Do it before you adjust the valves. 2 cents from tjs
Detro996
Check/adjust the rocker arm end play as suggested above.
If that does not solve it..... I had a very similar issue on my 1150GS. Finally tracked it down to one of the pushrods. The steel ends are pressed into the aluminum body. When the bike got hot the end would loosen and start ticking. I fixed the issue with 1200 pushrods (solid steel) but replacing with the original is probably more cost effective. ![]() ![]()
If you need your Hall Sensor plate rewired - PM me. Last edited by GS ADDICT; 11-07-2016 at 05:04 PM.. |
Detro996
Jeff
You have the new style and the R1200R cams. Cheers |
Detro996
Not sure if you tried this or if it would help, but did you look at the right side cam chain tensioner ?
2004 R1100S |
Detro996
I was headed there but Bill Wartzel said check the Rocker Arm Slop, he was spot on. I was about to just go ahead and order a tensioner as they are not that expensive. He said look elsewhere as he had never seen the new style tensioners fail. Like I said, learned something new. In fact I've come to the conclusion that is probably why some boxers are very quiet and others very noisy.
Thread Tools | |
Rate This Thread | |
