Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW Z3/Z4 Forum
BMW Roundel Z3 automatic
I have a 1997 Z3 2.8 with an automatic tranny. I typically do routine maintenance on my vehicles, and was suprised by not being able to locate a "dip stick" for checking fluid levels in the transmition. I refered to the manual, and it has nothing to reference for that type maintenance.
Am I completely blind, or is there no way to check the transmition fluid level?
Dazed and confused in South Florida!
Old 12-11-2003, 06:02 AM
BMW has not had a trans dipstick for a long time now.
You check the level at the trans pan(under the car)--there is a plug on the side of the pan that is removed to check the level with the engine running while the engine/trans is at operating temp
If the fluid is at or slightly above the bottom of the hole the level is ok
S
Old 12-11-2003, 09:38 PM
Thanks. That helps. Seems like something they need to reincorporate to their cars.
Old 12-12-2003, 06:57 AM
97740i is correct. I've searched and found out that your auto is a GM Hydramatic unit that uses Dexron III. I use Amsoil ATF in mine. Good luck! - Marvin
- Marvin BMWCCA
E28 84 528e auto (for sale)
E28 85 528e stick (for sale)
E30 84 318i stick 136k (sold)
E36/7 99 Z3 auto 250k(my son’s)
85 Mazda RX-7
94 Mazda MX-6
90 Chevrolet 3/4 Ton
96 Chrysler Town & Country
97 Chrysler Town & Country
I wish I had a Jitney
Old 01-24-2004, 06:08 PM
