Can I delete my AOS from the intake? (09 Cayman base)
Long story short I'm working on a friend's 2.9L with the usual smoke on startup issue and oil in the vacuum lines going to the intake. I changed the oil air separator but nothing has improved, still sucking in oil to the intake. There is obviously a bigger problem here like failing Nikasil coating on the block but he just doesn't want to see the smoke on startup. My question is can I just vent the AOS to the outside with a separate hose rather than doing it through the intake? Is there going to be any negative effects on the engine other than the reduced blow by?
Thanks |
Most likely, what you are seeing is residual oil in the intake system being burned off. You can either live with it until it abates, or pull everything apart and clean the oil out.
Accrochez-vous bien de vos rêves..........." |
I'm going to start by saying I respect your opinion on this topic or else I wouldn't be asking. With that said, what "oil seals" are we talking about here and what factor as a result of re directing the AOS vent causes them to fail? Sent from my iPad using Tapatalk |
The AOS is there for a reason.......
