Vibration under acceleration
2000 Boxster S with 90K. There is some vibration with acceleration that drops off as soon as you let off the power. Revving in neutral is smooth. No vibration when coasting. My local mechanic, not a Porsche expert, was thinking it may be the CV joints but there is no clicking or other noise. Any thoughts?
Old 03-11-2019, 08:00 PM
Behind the Sun
Motor mount.
Front one most likely.
I would change the 3 of them
Old 03-12-2019, 06:35 AM
The front mount was changed recently. I don't think the others were, but I'll check.
Old 03-12-2019, 10:09 AM
IMS?
Old 03-12-2019, 11:47 PM
Where do you feel it? Steering wheel? Braking? Seat of your pants? Could be lots of things until you narrow it down a bit.
Tony G
2000 Boxster S
Old 03-13-2019, 04:43 AM
My best guess is that it's a bad coil. I had a GM product that did what you describe. turned out to be a bad plug wire.
Brian Lamberts
Tucson AZ
Old 03-13-2019, 08:14 AM
It feels like it's coming from the rear. Steering wheel does not shake. No shaking while braking. It feels like a tire or suspension vibration, but only when it's pulling under power. Let off the gas and it stops. Rev the engine while in neutral and there is no vibration. Just when accelerating, or pulling up a hill.
Old 03-13-2019, 09:47 AM
Check your wheel bearings.
Tony G
2000 Boxster S
Old 03-14-2019, 12:02 PM
It'll be legen-waitforit
stealthn's Avatar
Agreed, check you rear CV boots, wheel bearings with the wheels in the air, check wear on tires, get them checked for balance as well. Good luck
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 03-14-2019, 04:29 PM
Update: Finally got it back in the shop. Left rear bearing was worn, but the vibration continued until both CV joints/axles were replaced. Also had a torn ball joint boot, and needed alignment. Now it runs great.
Old 06-12-2020, 09:42 AM
