99' Base 5 speed Cranks / No start / No codes / New CPS
Ok the title gives you the basic run down
Duremetric has no codes in any modules
Engine cranks
Immobilizer has no water ingress or corrosion internally
Central locking works normally
30 amp fuse is good (all fuses pulled and inspected)
Fuel pump does not primer with key on or cranking
Fuel pump will run with relay bypassed (still no start)
New Genuine Bosch CPS just installed (no flutter on tach while cranking)
I'm stumped, I think I've read a few dozen threads about no starts but none like mine.
Any suggestions?
Old 08-12-2019, 10:21 PM
Ok, got up early before the heat started and did some basic diag.
Fuel pressure while cranking 34-36 psi
Showed spark on rear cylinder LH side
Pulled the plug, wet with fuel
Tried a squirt of starting fluid no change. (open or closed throttle)
No codes in any Modules
Cranks smooth, no noise
Does anyone have a video of an M96 cranking with a broken timing chain?
I'm thinking there would be a code stored if it broke even if it's only cranking?
I have a spare 2.7 but I was hoping to avoid the engine swap.
Old 08-31-2019, 10:21 AM
JFP in PA's Avatar
Engine cranks
Any suggestions?
If you have no tach movement, the CPS is either bad or not communicating with the DME.
Accrochez-vous bien de vos rêves..........."
Old 08-31-2019, 12:44 PM
Tach does move now
Old 09-01-2019, 07:28 AM
