t2933rm
Porsche Crest Window will not drop on door open
I have replaced the regulator and the micro switch, but my 1998 Boxster passenger window will not drop the few mm to open/close door. It does come down automatically with conv. top switch, it works from window switch. looking for what i should dig into next?
Old 04-28-2020, 05:30 AM
Hi when you say replaced the micro switch do you mean the one in the lock mechanism as that is where the switch is to drop the window.
I messed around with my lock mechanism for ages cos the window stopped dropping. In the end I bought 2 lock mechanisms ( both doors ) and everything worked properly again
Old 04-28-2020, 10:08 AM
had same on 02 boxster s , didn't want to pull regulator cause it looked complicated and the window did go up and down and was tight in full up or down, inbetween i could pull window up or down a half inch, dove into it and not that bad a deal, replaced and works great,only thing is when you reconnect the air bag it triggers a light on dash, porsche wanted two hundred to reset, found a local for fify, ifn I had to do again might try to cut the insulator around bag and leave it plugged in
Old 04-29-2020, 12:29 PM
Tags
microswitch , regulator , window
