Temp sensor problem?
2005 Boxster S. A few minutes after startup, the temp is still pegged at cold. The coolant temp warning light comes on. Minutes later the temp rises to normal and the light goes out. Is this a sensor issue or maybe a thermostat stuck partly open?
Old 12-25-2020, 01:10 PM
Did you check coolant level?
Old 12-26-2020, 05:12 AM
Sensor problem
Yes, coolant level is just above minimum.
Old 12-26-2020, 08:37 AM
I’d suggest that getting it up to maximum would be your first step.
Old 12-26-2020, 11:58 AM
Tags
coolant temp warning , temp sensor
