Overheating issues
I am having over heating problems with my 2005 Boxster. Base model. Tank isn't leaking. Do thermostats fail in Boxsters often? Any help would be appreciated. Also I live in Florida so its always hot.
Overheating is a big problem. This can crack the head. I’d start by removing the front bumper cover and cleaning between the A/C condenser and the radiator. You can’t see between without taking it apart. It will have a ton of crap in there.
Also check the fan is working correctly. Start the car, turn on the A/C and both fans should be running. These fans can fail and may need replacing. Start there. Step 2 is cleaning between the rad and condenser. Don’t wait.
Tony G 2000 Boxster S |
fyi- mine had a hairline crack on the tank bottom.It didn't leak until the car was well warmed up, and the leakage was small but steady then.
1999 Carrera2 tip arena red 2000 Boxster S tip...arena red ....black 1981 911sc targa...grey mkt.import...Rosewood 1978 911SC, guards red sunroof delete .much missed 73 914 2.0 found in a bunch of cardboard boxes, and brought back from the dead. |
Thank you for the information. Much appreciated..
Are the fans comming on? Start there.....
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
cleanin out the area in fron of the radiators is mandatory, i put screening over theg rills in to prevent the build up of leaves and crap
