I hope someone can help me.
The other day I noticed I was out of washer fluid "cause the light was on" I put in more fluid, the light turned off but nothing comes out when I try to spray it. I can hear the motor running but nothing. then after a while the light comes back on. I filled it again and NOTHING! Now I know there is likely a break in the line to the holder where the fluid is held OR a break in the container. My question is where is it? and Can I get at it to fix it myself? Please help |
Was there a leak? You should be able to follow the pathway from the tank to the leak. If the level is going down in the tank you have to have a leak. If the level stays the same and you are not getting fluid then trace from your pump out to the nozzel, probably a plug.
