is this common problem?
ok couple times when i drove my car seems like the PASSENGER window was coming down and up (boxsters when you open door window kind come down half inch and up again} i noted in big bumb or just driving it couple times ! i think is a little sensitive any how i drove car with wife Sunday i noted now window doesn't come dow little when open the passenger door at all? my power window work fine even when take cabrio top down windows came half was down normally no problem!,, is this something i have worry about it common issue bad switch what cause that to happen? thanks
Old 03-08-2010, 02:46 PM
Author of "101 Projects"
Wayne 962's Avatar
Bad switch or a bad regulator - I have seen both in my car. The regulator was so worn that it would move the motor, but the window wouldn't drop down. Replacing the regulator fixed the problem. Or, the actual switch in the handle and/or the lock mechanism may be at fault.
-Wayne
Old 03-08-2010, 03:58 PM
JMatta's Avatar
It's in the book, right Wayne?
Buy the book when it comes out!
'73 911 Frank 'n Meanie
2002 Boxster S
PCA Instructor Circa '95
Old 03-08-2010, 04:36 PM
