Guest
Posts: n/a
I have a 1999 986 and the key will not lock the door. I have not used the remote key because it is broken. Will a new remote key enable me to lock the door or do I need a new lock
__________________ This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Door Lock Mechanism / Door Handle - 986 / 987 (1997-08) - Pelican Parts Technical Article |
I would assume you need a new lock or latch if the mechanical key isn't working.
- Nick |
Louis,
If the key turns in the cylinder then the shaft going from the key cilinder to the lock mechanism is disconnected. Neither of my doors would lock and after i investigated by taking the door panel off i found out the horizontal shaft on the driver side was out of the slot. On the passenger side the shaft wsa in the door locking slot but a tiny pin fell out where the horizontal shaft attaches to the door handle.
SteveKJR Proud Owner of a 78 911 SC Targa "A Porsche does more then just go fast in a straight line" |
