RickKlem's Avatar
Location: Seale, Alabama (25 miles south of Auburn, Al.)
Need help with top replacement project
I'm in the process of replacing the top on my 2000 Boxster. I have read through the detailed instructions that came with the new top and I have read through the DIY that Mike Focke posted ( Good job Mike, Thanks) .
My question, The instructions say to use the 3M adhesive upholstery spray but Mike mentions to use the 3M double side emblem tape. Does it matter which I use ? Is one better than the other? To me it seems , that the spray would be less forgiving. Once it is on it is there for good. If I made a mistake with the tape I could just use another piece.
Is the tape strong enough to hold everything in place?
Rick
Red 1977 911s 3.0L (27230)
2013 Base Cayenne 3.6L
Old 06-17-2010, 01:48 PM
Most upholstery shops use the 3M Adhesive.
Old 06-17-2010, 05:00 PM
RickKlem's Avatar
Both of the products that I mentioned are 3M adhesive. I need to know if I should use the double sided tape adhesive or the spray adhesive ?
Old 06-17-2010, 05:19 PM
Author of "101 Projects"
Wayne 962's Avatar
I don't recommend the spray adhesive. We used the 3M-style double-sided adhesive when we did the top replacement for our article:
Pelican Technical Article: Convertible New Top - 986 Boxster (1997-04) - 987 Boxster (2005-08)
-Wayne
Old 06-18-2010, 03:24 AM
RickKlem's Avatar
removing adhesive from new top
I'm in the middle of the top replacement project and it is going pretty good. I had some wrinkles on the passenger side when I glued the new top to the aluminum plate . So I removed that plate and am in the process of cleaning off the adhesive. I was able to remove it from the plate but I'm having problems getting it off the new top.
I use the double sided tape in some areas but here I used the 3M super yellow adhesive.
Any ideas on how to remove the adhesive from the top without damage?
Rick
Old 06-27-2010, 01:55 PM
RickKlem's Avatar
AND, If I cant get the adhesive off of the new top, Will it be okay to add more adhesive to both parts and then reinstall it? I know that it is recommended to clean off all old adhesive , but in this case if there is still some "cured" that cant be removed , will it be a big deal?
Old 06-27-2010, 02:55 PM
Don't have a boxster,I'm an old 930 guy, but I happen to be doing a boxster top transmission update for one of my son in laws on his 99 boxster.
I recently replaced the headliner and carpet in the 930 and used the 3M adhesive. I bought a quart can and applied it with throw away paint brushes. I found a heat gun works well for removing glued down pieces that need to be pulled up or repositioned. For cleanup and removal of the adhesive use final- clean
it is a prep cleaner for wiping down parts before paint. I have used it for years on everything for clean up and prep. You can get it at any auto supply, you'll find it referred to as final clean, final prep, oil and wax remover, surface prep. It works well on cloth, carpet, and vinyl surfaces. If the weather strip cement has dried just heat it with the heat gun and then clean it off with final clean on a rag. It will soften and lift the cement or ball it up and it will then lift off.
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 06-27-2010, 03:01 PM
RickKlem's Avatar
Cole,
Do you remember the exact name of the product or the manufactor name ? The auto paint shop has does not know of a product called "final clean" .
Thanks fro any help
Old 06-28-2010, 05:10 AM
