2000-2002 boxster
Thinking of purchasing a 00-03 boxster; anything in particular i need to know or to look out for?? Maintenance items, problem areas,etc. Any would be helpful. Thanks
71 Targa 2.4 WEBERS 915 box Drivetrain - http://forums.pelicanparts.com/porsche-911-technical-forum/410787-drivetrain-project-complete-3yrs-pics.html Interior - http://forums.pelicanparts.com/porsche-911-technical-forum/452686-interior-refurb-carbon-fiber-71-a.html#post4433500 |
Author of "101 Projects"
I like the 3.2 'S' cars personally - the pricing differential between the S and non-S is getting to be pretty close these days, and the performance difference is significant. Check for frequent oil changes (3000-5000 miles max), as that seems to be the number one way to help reduce engine failures...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Mark from SC
I went with the 03 'S' mainly because the 2003 model had the glass rear window, and the 'S', for the power difference.
Mark |
poke around here
and you'll find all I have been able to learn in the last 6 years of owning 2 and reading lots of forums.
Link There are buying comments, model year differences, problem areas, ten best and worst, etc. pages. |
The 'S' is a must.
I would put a '03+ high on the list due to the glass window. I'm regretting not having it. Looking to upgrade the top for it.
M |
-Thanks
71 Targa 2.4 WEBERS 915 box Drivetrain - http://forums.pelicanparts.com/showthread.php?t=410787 Interior - http://forums.pelicanparts.com/showthread.php?p=4433500#post4433500 |
There are 2 ways of going glass window on a pre-03 car. Buy a frame and top from an '03-04 wreck. Easy DIY for 2 people. Or buy a top that is a replacement top with the glass window from an aftermarket supplier. A lot of work to install but cheaper.
The shape of the '03-04 top is slightly different but it fits with no problems and it works better for accessing the engine bay. The replacement top (GAHH is one supplier) is probably 1/3 the cost and harder to install. Both work very well once installed correctly. To see how much work...go to the TOPs section of my web site at thetop-itsmaintaince&replacement - mikefocke2 |
I realize that I am "hijacking" this thread, but I have question about installing the GAHH top.
Because I have a hard top for the winter, I don't need to have the soft top or its frame on the car for about 4 months per year. Would it be possible to install the GAHH top without having the soft top frame installed on the car? That way I could work on the project over the course of several weeks during the winter. I find that having the option to walk away from a project of this type when it becomes frustrating leads to better results for me. It also appears to be two-day job and I rarely have two full days in a row to devote to this type of task. |
