Author of "101 Projects"
The aircooled 911 motor is way more difficult than the Boxster motor, in my opinion. The Boxster motor is one of those things that is difficult to put together backwards. The older aircooled motors you can put a lot of things on the wrong way...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Back to the noise on start up. I had valve train noise using 0w-40 Mobil 1. I since changed to 5w-40 Motul and hear nothing. Yes, it was only 1 to 2 seconds with a full 2 seconds probably being too long.
Thanks |
I think it's pretty doable - the full procedure is documented in my tech article. If you're complete and thorough and you check your cam timing when you're done, then you should be A-OK and should have no problems. If you're sloppy and don't follow all the steps, then you might have some issues.
-Wayne
I completely agree with Wayne on this one... even if you are not mechanically inclined, can successfully accomplish several tasks on the Boxster, no need to be a german engineer... just prepare correctly
.Wayne, as far as doing the IMS bearing replacement, its ok without dropping the engine, right? |
-Wayne
