I have removed mine thru the interior hatch for inspection/cleaning. Removed the electrical connector bracket in front of it for more access. It's tight but not too bad of a project. It's just a pressure valve with free flowing vacuum from the crankcase but I guess if it's gunked up enough it could cause problems.
I just changed this and thought I'd add some help to others.
Yes, you have to take off the cover behind the seats, and I pulled out that electrical connection in front of it too. I was able to use two long 1/4" extensions to come in from the top, while looking from the side to loosen the bolt. Once it was fully loose, I used one of those long reach spring finger grabbing thing to grab the bolt and pull it out without losing it. I used a small screwdriver to pop the valve up and out. I pushed the valve and hose backwards. Then from under the car (with the car up on ramps), I was able to pull the hose down and swap the valves. I pushed it back up. It was a little difficult to rotate it around to line it up. But, I succeeded. I then used a small mirror and small screwdriver to move the valve into position and down into the hole. I put the bolt back into the valve using the springy grabber thing. I then got the socket on the end of the long extensions and was able to lightly turn the bolt. I think I had a LOT of luck that the threads lined up and I was able to thread it down without crossing the threads. But I did turn very slowly with light finger pressure to get it started. We'll see if it allows my air oil separator to last longer. This is my second replacement. A shop did it the first time. By the way, elsewhere, on Pelican it says there are two of them. I could not find a second one. |
No expert but have replaced mine twice in 90k. That soon sound like either really bad luck or super excessive blow by/ crank case pressures from bad rings. Maybe a compression or leak down test would eliminate that. I would suspect you would be smoking quite bit if it were that bad even with a new AOS. Oh much easier to access with the axel out but I just got lucky on that one.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci 2007 Ducati 999S Team USA , 2005 BMW BCR R1100S 2001 Boxster S w/tip |
Schnell Gelb
This issue is covered including part number references to Pelican and part numbers here:
anyone ever replace the PCV valve? - 986 Forum - for Porsche Boxster Owners and Others It would make a great DIY subject because it is soooo tedious.And if you drop the little bolt or cross-thread it ! I suggest replacing the original bolt with one that has a chamfered lead/nose and an internal hex drive so you can use a little weak adhesive or electrical tape.
2001 Boxster S Engineers muse Last edited by Scnell Gelb; 11-08-2017 at 09:13 AM.. |
I have "normal" size arms but they aren't triple jointed. The biggest problem I'm having is squeezing the lower hose connector so that I can pull it free from the AOS. Also, I've never seen any mention of trying to clean the flex hose between the AOS and throttle body? It seems to me this should be a priority if you are cleaning your throttle body, since that is the main path contaminates follow. Thanks for all of the hard work putting together the book and How to Articles. Jim |
Any links to an AOS rebuild? Ive seen some ads offering a single membrane at a cost of less than $10, and picked up a used AOS as well, so curious as to a writeup for this?
Complete waste of time. The AOS was not designed to be disassembled, and the aftermarket diaphragms are of unknown quality or longevity.
Accrochez-vous bien de vos rêves..........." |
I did the whole thing this week. Changed AOS, crank case vent valve and upper and lower vent hoses. Changing the AOS, vent valve and upper hose was not terrible. The lower vent hose was a nightmare. Mine was cracked and broken. I detached the old one from the vent valve and the AOS.. removed the old AOS and vent valve. Removed the throttle body and two cross tubes ( I have a 3.2). I cut the old lower vent hose in half and pulled it out. The stock pipe is pretty stiff plastic. I considered doing a work around with 3/4” PCV hose. Unlike other hose, PCV has reinforced walls that won’t compress under vacuum. I was going to use the end of the stock hose and attach them with clamps. I decided to give one good try with the new stock vent pipe first. I also detached the oil filler neck from the block so I could snake the new vent line in. It took 2 days to get it in. I did the drivers side first. It is very difficult. You have to force it in under the plenum. It’s very stiff and has a bend. It can be done but it’s very difficult. A lot of force and swearing is needed. Once that side is in you have to bend the plastic pipe in order to get the other side in. The new pipe is stiff but will bend with force. The passenger side has more flex and you can get it in. I strongly suggest taking a picture of everything before you take the old hose out so you can see exactly how it snakes through. It was the most frustrating work I have ever done on the car. I won’t do it again. If I had to, I would use PCV hose. The stock pipe is trash. During the process I replaced my vacuum lines, they are right there and mine were bad. Also cleaned the throttle body since it was off.
No need to roll the dice on this one. Use Genuine Porsche only. The aftermarket ones are pure junk. If you track your car, put a motorsports one on and make sure you run your oil level on the min. mark. Overfilling is the fastest way to kill your AOS (and engine). Here is an article on the AOS and PCV system:
Tech Tuesday: Understanding the PCV System and AOS - by Tony Callas
Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution |
I replaced the pcv valve and it still blows oil does this mean aos bad even though no smoke. Not enough vacuum
I replaced my presume relief valve still blows oil. AOL was replaced awhile back but is not smoking. Could it be bad and causing backpressure. Any suggestions.
I changed it from behind drivers seat with universal 10 mm socket. Hard to get pinch hose off used rubber hose with wrench handle and slid over pcv valve to push back on hose.. slid hose over pcv and ran to bottom of car to check for oil. Still blew oil. Must have something causing backpressure or to much oil blowby. Any ideas.
Something I have learned with my 986 S. Have had it since 02. When working on anything , you can see it or touch it, if you can do both it’s way to easy.
They may, but considering the effort it takes to remove the AOS, it makes little sense to take it apart, replace a part with one that may or may not work, and then reinstall it. When the digital manometer reads too high, just can it and put in a new one...……….
