DTS DTS is offline
O2 Sensors
I have a 1999 Boxster with 54,000 on the clock that I picked up in February. Car is running fine but the check light came on the other day, all o2 sensor codes P0151,p0131,po157 and p0137.
I have no maintenance history on the car. Something tells that all four cannot be failing at once. The car is running fine, no performance issues.
I may check all the connections, but is there something else I should be looking at? Any thoughts?
Old 05-18-2011, 08:36 PM
Cajundaddy's Avatar
Those codes indicate "short to ground" on all four sensors. Possibilities:
Sensors were replaced and mis-wired/wrong sensors
harness is damaged (rodents, heat from contact with aftermarket headers)
DME is failing
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 05-20-2011, 07:27 AM
DTS DTS is offline
Thanks for your help. Wayne, love your book, you have already saved me at least $1,000 bucks in repairs.
Old 05-20-2011, 12:03 PM
