Getting misfire under similar conditions
NO further issues!
Old 06-16-2011, 02:25 PM
And the Pcode behind the CEL is....
Old 06-17-2011, 06:40 AM
Don't have the equipment to retrieve that.. apparently there's a guy in town with a durametric, is that all I'd need?
Old 06-17-2011, 10:15 AM
I had the P0306 (same cylinder) under heavy throttle/higher RPMs. Replaced the coil pack and problem solved. Does the coil look cracked and ugly? Do you get anything under heavy performance?
I hesitate to advise here, because I'm very new to this stuff, but maybe you have more of an oil or fuel problem. Is this old gas?
A while back, I had parked on a sideways slope for a couple weeks, and found the car running very rough and smoking, but that eventually went away, after parking level and driving for around 5 minutes on 4 or 5 separate days. I think oil leaked into a cylinder and had to drain/burn off. I replaced all the sparks after that, and now she running fantastic.
I was sick to my stomach over this until it resolved though (a week or two), so I wish you well here.
Gents: why is the "Pcode behind the CEL" not the P0306 mentioned? What else is going on here that I don't understand??
Old 06-22-2011, 07:46 AM
I have a plug/coil/tube on order. Hoping one of them rectifies it. No issue after the first 30 seconds after start up only when sitting for more than a day
Old 06-22-2011, 04:39 PM
