Wine Country Farmer
marosmith's Avatar
I purchased a Boxster, now I have some dumb questions...
Edited based on correct info:
I just purchased a ocean blue metallic 2000 Boxster, I believe a "Sport" model with two remote keys, digital CPU readout, electric seats, upgraded chrome wheels, CD changer, wind deflector, leather wrapped dash etc...
It has 68k miles and detailed service records so for $10k I thought it was a great deal.
I have a couple questions:
1. Can I purchase the dual cupholder that comes in the 2001+ models and move the stereo down two notches into the bottom cubby holder?
2. Is there an aftermarket Ipod type interface, like a passthrough that connects to the CD changer?
3. How do you reset the trip meeter, and does it calculate MPG per trip?
Thanks.
Old 08-04-2011, 11:22 PM
Aron in Toronto's Avatar
Congrats! Great color combo.
Originally Posted by marosmith View Post
I just purchased a midnight blue 2000 Boxster, I believe a "Sport Design" model with two remote keys, digital CPU readout, electric seats, upgraded chrome wheels, CD changer, wind deflector etc...
Looks like you may have the "Sport" or "Sport Touring", not the "Sport Design" package. The Sport Design package came with sport seats with added bolsters at the shoulders, a "granite" like speckled finish on the center console / seat-backs and a diamond pattern texture on the door panels and areas of the dash.
Yes you can install later cupholders and shift the A/C or stereo down. You'll need to buy some additional trim pieces though. Some say these cupholders are still a poor solution and many recommend the "Ultimate Cupholder". A search should give you some more info on both options.
Yes depending on which head unit you have. If you have the Becker CDR-210 (or CR-210) there is no aftermarket cable that I'm aware of to add an iPod, other than an FM transmitter type. If you have a later CDR-220 or CR-220 then there are many sources for AUX input cables that replace the trunk mounted CD changer. Becker Sound USA offers a cable but the price is high at around $110 for the cable and another $11 for the head unit removal keys. There is a vender on eBay that offers a similar cable for around $30 IIRC and the removal key can be found on Ebay as well.
http://www.pelicanparts.com/techarticles/Boxster_Tech/88-ELEC-Radio_Install/88-ELEC-Radio_Install.htm
You should be able to push the stalk on the odometer to reset the trip meter. If your car has 4 stalks levers (wiper / turn signals / cruise control / the forth being the on-board computer) then you have access to the more advanced functions of the trip computer readout that gives you the option to scroll through Av MPG / miles left in tank / outside temp and probably more info as well, though I'm not sure as I don't have this feature.
Thanks.
Aron
1997 Boxster
Old 08-05-2011, 06:17 AM
ProjectM96's Avatar
Nice find. I bought my 2000 Boxster 9 months ago for the same price with similar miles.
1. Yes
2. Yes
3. Depends on if you have the smart computer that calculates MPG. I do not have it in my Boxster. In my car, I push the button by the trip monitor and hold it down for about 2 seconds to reset it.
Porsche Boxster 986
Old 08-05-2011, 07:20 AM
ronster's Avatar
All the Boxsters have active on board computer access built in to the car and was an option at the time of purchase. Access can be added by pulling the instrument cluster off and unplugging it. Looking at the plug you have to tap into position #25 (don't take this as gospel as mine was done over a year ago and I was watching). You can do a couple of things, you can add the four stalk accessory by purchasing a new or used one and pull your steering wheel and installing and hooking it up or do like I did and add it as an accessory switch on the dash board. I had three empty positions and selected the garage door opener switch and hooked it up through that. Now I can push the switch and get a readout of mpg, miles left on tank of gas, temp, avg. speed and could have had the chime for exceeding speed limit but opted to not. I'll try to find the hack for this and post it here for you or you can do a search for OBD hacks on some of the sites and find it. The switch way is the easiest and least expensive the most expensive would be to have the dealer do it.
Old 08-05-2011, 08:30 AM
Wine Country Farmer
marosmith's Avatar
Yes, I meant Sport, not Sport design. I do not have the extra stock on mine to control the CPU, I will hold the dimmer button down and see if that resets the trip mileage.
"Ultimate cupholder", any links to this?
Old 08-05-2011, 01:20 PM
BMW Cup Holders, Porsche Cup Holders, Ultimate Cup Holder - Cupholders / Drink Holders for BMW 3 5 7 Series, Boxster 911 Z4 Mercedes Audi NSX other fine cars.
Aron
1997 Boxster
Old 08-05-2011, 02:50 PM
ronster's Avatar
Here's the hack I'm referring to.
OBC Hack
Old 08-05-2011, 03:43 PM
Wine Country Farmer
marosmith's Avatar
Wow, that could be perfect. I'll get one.
Thanks!
Old 08-05-2011, 04:43 PM
Doug&Julie's Avatar
Totally off subject...Lafayette...LA or IN? ..or other?
Doug
Currently Between Porsches
PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944
Old 08-05-2011, 05:05 PM
Wine Country Farmer
marosmith's Avatar
Nope- Lafayette Oregon, think west and in between Salem and Portland on the way to the beach.
Old 08-05-2011, 05:17 PM
Wine Country Farmer
marosmith's Avatar
Also,
Does Amsoil 5w-40 work on this, of is 10w-40 preferred?
Is premium fuel needed, or is super adequate?
Old 08-05-2011, 10:45 PM
ProjectM96's Avatar
Also,
Premium fuel is required. It says 93 octane required, but I called Porsche since the gas stations in my area only served 92 octane as their premium gas.
Porsche said 92 octane was acceptable, but the minimum.
Using Super will increase the chances of engine knock, since it is more likely to combust prematurely in the cylinder.
Higher octane fuel has a smaller chance of combusting too early, which is needed in powerful engines where premature combustion(engine knocking) can occur.
Porsche Boxster 986
Old 08-06-2011, 11:35 AM
Doug&Julie's Avatar
I thought that scenery looked awfully hilly for either LA or IN. Ah, Oregon...how we love thee...
Doug
Old 08-06-2011, 12:21 PM
Wine Country Farmer
marosmith's Avatar
Those pictures were taken in Bend out east.
1999 996 Porsche Cab
2006 E91 BMW AWD 6 speed
2019 Ford F-250
Old 08-06-2011, 02:45 PM
Garrytw's Avatar
Send a message via Yahoo to Garrytw
bad link to the hack page...
Garry Whitcomb
2000 Boxster 2.7 Arctic Silver
1973 VW 1915cc, Baja Bug
Old 08-06-2011, 07:45 PM
One question I have never seen answered anywhere (although I have seen it asked) is if the hack works on the later 986's, like my '03, for instance. Any comments from anyone who owns one of those cars?
Thanks!
Tom Coradeschi
03 Boxster
Old 10-02-2011, 11:10 AM
Ouzo12's Avatar
Car Audio Innovations sent me a kit that i had a local shop install. I believe they hooked it up the Cd Changer slot. Charges the iphone and gets clearer sound than using the headphone jack.
“I will drive flat out all the time. I love racing.” - Gilles Villeneuve
Old 10-02-2011, 12:00 PM
ronster's Avatar
Here's one on Pelican.
Boxster On Board Computer Activation
Old 10-02-2011, 01:07 PM
bar10dah's Avatar
What's the issue with the factory cup holders? Bad location? Easy to dislodge/spill?
Old 10-02-2011, 02:44 PM
cowfly911's Avatar
I installed this (link) into my 2000 Boxster S and it works great with my iPhone 3GS.
BLAU/8-POD iPod Adapter for select Blaupunkt & Becker Radios :: iPod Adapters & Interfaces :: Discount Car Stereo
1983 911 SC "RoseBud"
1980 911 SC "Silver"
1966 912 "Red"
Old 10-03-2011, 05:15 AM
