rpjasin (guest)
Guest
Posts: n/a
This article is confusing on the 5 speed transaxle. Why do you state "Pump the transmission case full of fluid until it just starts to run out the filler hole", and later in the article it states that the oil should be "11 mm below the plug opening"? Please explain, Thanks!
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Differential / Manual Boxster Transmission Fluid Change - 986 / 987
Old 09-04-2011, 08:53 PM
Author of "101 Projects"
Wayne 962's Avatar
Sorry about that, you're right. That's for the six speed (fill until it runs out of the hole). The 5-speed should be a little bit less. I don't know why Porsche made it this way, nearly every other transmission on earth does it where you fill it up to the bottom of the filler hole.
- Wayne
My filler plug is a star shaped that I took out with a 9 mm hex. It also seems to be higher relative to the axle. 986 1999 Boxster. The filler plug has a round dipstick like protrusion. Have I pulled the wrong plug?
Old 04-21-2020, 08:07 AM
Can you post a pic?
PCA National HPDE Instructor
2008 Boxster S Limited Edition #005
2008 Cayman S Sport - Signal Green
1989 928 S4 5spd
Old 04-22-2020, 05:31 AM
Fill plug requires special tool
https://www.ebay.com/itm/HAZET-2567-16-Oil-Service-Socket-for-Porsche-VW-Audi-M16/231228010019
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S
'01 Boxster
Old 04-28-2020, 08:17 AM
