matt (guest)
Guest
Posts: n/a
When you replace the AOS, do you recommend replacing the o ring on the bottom right angled connection into the right side of the engine? part number 996 107 122 00.
Also, I changed my AOS a few months ago, but i am again getting smoke on start up. I disconnected the line from the AOS to the intake & found oil. Could the new AOS be faulty, have there been a bad batch or is it some other problem in my car?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Air / Oil Separator Replacement - 986 / 987
Old 11-11-2011, 05:39 PM
Author of "101 Projects"
Wayne 962's Avatar
Sure, it's a smart idea to replace the o-rings on all of the connections that you've disturbed. If there is a big vacuum pull from your engine, it will cause air oil separator units to fail prematurely. Too much vacuum can be caused by a broken / stuck crankcase ventilation valve. I would check that it's not pulling too much vacuum on your engine.
- Wayne
