Guest
Posts: n/a
I did the swap and it works great.
why can't you use a tt gauge cluster? the unit i got goes to 200 mph,is this from a turbo? __________________ This post was auto-generated based upon a question asked on our tech article page here: 996 Gauge Cluster Upgrade |
Author of "101 Projects"
I think technically, the Turbo cluster will work with some functions. However, I think the gas gauge is different, so you won't have an accurate reading there, and I think one or more of the other functions won't work properly either. I think if you have a 200 mph gauge, it might be from the Turbo, but I'm not 100% sure.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
I think most 996 gauges go to 200 mph
I think the turbo cluster is different for two reasons: a) gas tank size b) the turbo has a true dry sump, so the oil level measurement on a wet sump engine (example Boxster) doesn't work
2009 Carrera 4S, PDK 1990 964 Targa 2018 Range Rover Velar |
Does anyone with an early Boxster have a gas gauge that works correctly? Mine never has even though I spent over $400 trying to fix it and every early Boxster owner I talk to says they rely on the remaining miles readout from their OBC. I did the OBC hack on mine for less than $15 and it is what I use now as my gas gauge never reads full even when I top it off.
Mine works correctly with both the original and replacement 996. The key is if you remove the cluster with less than a full tank you will have to recalibrate the cluster with the fuel sender. I'm not certain of the process but I understand it is pretty involved and requires a PS2.
99 Boxster 5-speed 12 Acura TSX 6-speed |
If you've tried everything else, I would bet that might be the problem. -Wayne
