Guest
Posts: n/a
Is there any way to depress the lock pin in figure 3 step D without having a key? I know you need the key to release the locking assembly but is there any way around this?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Ignition Switch Replacement - 986 / 987 |
Author of "101 Projects"
I think that you can remove the entire ignition switch assembly without the key (Figure 4), but not the key assembly itself. At that point, you'd have to probably replace the whole mechanism.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
