LinkBack | Thread Tools | Rate Thread |
Boxster turns over but wont fireHi all, wonder if any one could help
Hi all i wonder if anyone could help, I'm running a 2.5 1997 Boxster it has covered 150,000 miles but always kept serviced, the other day i fired her up and it ran lumpy then cleared i assumed because it had sat a while, I then tried again yesterday and it fired then died, and now it wont fire, it turns over, i cant here the fuel pump buzz, and there seems to be a strange electrical/hum from engine compartment, I took out fuel pump relay and bridged 30-87, the fuel pump runs but it still will not fire, I only changed the coil packs 6mths ago.
Can any body please help, Also when it was running it always idled lumpy and there is a gasy smell and the obii reader says it has multiple cylinder misfire but it drives lovely. Ive looked on the net and it seems this is a common fault which no one can get there head around including Porsche/Porsche North America. Thanks every one and happy Xmas Cheers Darren Last edited by Retrobuggy; 12-22-2011 at 03:07 AM.. Reason: additions |
Author of "101 Projects"
Can you tell us what the codes are that being output by the computer:
Pelican Technical Article: Reading Boxster Fuel Injection Fault Codes / Diagnosing Problems - 986 / 987 -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Hi, I'm afraid there is now no codes in the car, Ive got a horrible feeling I may of accidentally erased them. sorry, I just remember it said 4 codes each picking a particular cylinder with a misfire.
I've seen some other posts where folks had cars that cranked well but wouldn't start and it turned out to be the fuel pump. There is a test port on the fuel rail where you could hook up a gauge.
Still no joy, sorry if i sound thick but I cant remember if the fuel pump primes when you first turn the ignition on, if it does then I may be getting fuel starvation of sorts, any ideas?
