Stavros (guest)
Guest
Posts: n/a
Today my 2005 top stopped working, while opened fully. The switch clearly works because the screen displays that the convertible top is closing when I wiggle it, but NOTHING happens physically. There is no motor noise, nothing. I can't close the top. I pulled the fuse e3 and replaced it with the spare 30 amp fuse, nothing changed, still doesn't work. Help?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Convertible Top Repair - 986 / 987
Old 12-27-2011, 11:59 AM
Author of "101 Projects"
Wayne 962's Avatar
The first thing I would check would be the motor in the back. Remove the motor and/or wire up 12 volts to it to see if it's operational. Then, just start backtracking from there if the motor works. You can also check to see if there is 12V getting to the motor when the switch is pressed.
- Wayne
Does your e brake micro switch work?
I am here: http://maps.google.com/maps?ll=37.502360,-122.256825
2009 Carrera 4S, PDK
1990 964 Targa
2018 Range Rover Velar
Old 12-27-2011, 06:32 PM
I'm in the process of building a 987 race car and have all of the parts for the top for sale. Let me know if you need anything.
Old 12-31-2011, 01:53 PM
Is it a light grey top by chance?
Old 01-05-2012, 04:37 PM
