Guest
Posts: n/a
Today my 2005 top stopped working, while opened fully. The switch clearly works because the screen displays that the convertible top is closing when I wiggle it, but NOTHING happens physically. There is no motor noise, nothing. I can't close the top. I pulled the fuse e3 and replaced it with the spare 30 amp fuse, nothing changed, still doesn't work. Help?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Convertible Top Repair - 986 / 987 |
Author of "101 Projects"
The first thing I would check would be the motor in the back. Remove the motor and/or wire up 12 volts to it to see if it's operational. Then, just start backtracking from there if the motor works. You can also check to see if there is 12V getting to the motor when the switch is pressed.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Does your e brake micro switch work?
--- I am here: http://maps.google.com/maps?ll=37.502360,-122.256825
2009 Carrera 4S, PDK 1990 964 Targa 2018 Range Rover Velar |
I'm in the process of building a 987 race car and have all of the parts for the top for sale. Let me know if you need anything.
