Anothe IMS save
Last week I did an 02 Boxster S, one of my cars for resale. did not have any signs of oil leakage or fragments in the oil filter but the cam deviation was out of spec. When I got the bearing out it was definitely bad. there was axial play that did not belong. After replacement, the cam deviations for both banks were dead on 0.00 Now it runs so much smoother than before and I have more confidence that the engine is healthy.
Just another day at the office. ![]()
Crazy Austrian http://www.ws-ab.com |
Hi harry...I'm in the market for a 986 S with the IMS fix: can you point me to a listing for yours?
How did the car drive with the cam deviation compared to after correction?
Thanks!
2001 Boxster 'S' . 1997 Boxster; my (former) DD, now resting in peace (or rusting in pieces!). 1998 BMW 323iC; my son's DD.....now. 1985 (early) 944; gone now, but not forgotten. 1974 Fiat X-1/9; my first mid-engine car. |
Is the durametric deviation read out limited to certain years. That sure would be a greg preventive maintenance tool on my 01S.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci 2007 Ducati 999S Team USA , 2005 BMW BCR R1100S 2001 Boxster S w/tip |
you can read the deviations for all the years and the actual cam degree values as well and you are right that it can be a good tool for preventative maintenance
Harrycb,
Few questions: You said the cam deviation was dead on 0 after the change. What was it prior to the change and if it was it steady at the deviated level or wavering?. Reason I ask is Durametric is reading mine as -4.22 on Camshaft position 1 and -6.11 on position 2 and they are both steady. I read that as long as they are steady it should be fine and need not be 0. Did you replace with Porsche IMS or LN ones? What made you pull out and look at the IMS even though there weren't any symptoms? Thanks. |
Have you had the opportunity yet to replace an IMS on a 06-08 987?
Just wondered how many more hours were involved in yanking the motor and splitting the cases to replace the IMS. |
Mike, you are looking at a cost approaching a total rebuild. It really makes no sense to reuse several components once you have gone that far, so you may as well strip it down entirely and re-ring and bearing it while you are in there. The bearing and shaft end up being a minor part of the entire job……..
Accrochez-vous bien de vos ręves..........." |
JFP--that's what I was afraid of; depending on how far you want to go, assuming the bore is OK, we're talking tensioners, rod bolts, IMS, oil pump, lifters, clutch and more-- a lot of money $10-15K? That is a very difficult call for me to make if it were to happen.
I can just see me having that discussion with the wife saying "well, I found some metal in the filter and we need to do some preventative work to save the block--about $15K worth prevention". I don't know if I'm that good of a salesman. |
Harryrcb,
You're 420 miles from me. When I'm ready for the IMS fix, I'll be coming down to see you... ![]() |
2001 Boxter S
You cannot realistically just take the engine apart, put in a new IMS shaft, and throw it back together again and expect it to be pristine; it won’t be……..
Accrochez-vous bien de vos ręves..........." Last edited by JFP in PA; 02-09-2012 at 01:17 PM.. |
Sorry I took so long to get back with all of you JFP answered this. Quote:
Thanks I will be eagerly awaiting your arrival. Come on down. Quote:
Your on. Come on down, the bar is always open
závodník 'X'
Haus of Harry campaign slogan - Save a Boxster! Well done sir.
Scott |
