LinkBack | Thread Tools | Rate Thread |
Guest
Posts: n/a
Wayne,
You apparently missed this statement in my Renntech write-up while developing your procedure: "For example, fuel gage problems with a C4 cluster due to fuel tank design or oil quantity/car leveling errors with a Turbo cluster due to engine sump differences were some of the problems to be avoided." The oil quantity can not be displayed electronically, on the instrument cluster, prior to starting the engine if a TT instrument cluster is used. I believe the TT has a "dry sump" oil system. Bill __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster 996 Gauge Cluster Upgrade - 986 Boxster (1997-04) - |
Author of "101 Projects"
Actually, I do mention that in the text above (5th paragraph) - don't use a Turbo cluster, and don't use a C4 cluster. Thanks for helping to clarify for everyone else.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
I have a C4 cluster and it's not thaaaaaat bad.
The car basically thinks that you have a 20 gal instead of a 16 gal tank. As long as you remember that the 1/4 mark equals "low fuel warning" you're good. The only thing that really no longer works is "miles to empty"
2009 Carrera 4S, PDK 1990 964 Targa 2018 Range Rover Velar |
You write on page 279 that you need a 24 mm deep socket to remove the original oil pressure sensor - which is right. But then you write that you need a 24 mm crowfoot wrench to install the 996 oil pressure sensor and that is wrong. I don't remember which size it was but it was either a 17 mm or 19 mm crowfoot wrench. Cheers
Thread Tools | |
Rate This Thread | |
